Solar and EV's - Great Investment!
    One thing that keeps crossing my mind lately seems to be a gray area not mentioned much, if at all. If I have a vehicle sufficient for my transportation needs, and fairly new, and I "like" it, where would I put the cost of a new EV to justify an oversized array ? Seems to me the only way to justify an EV before the end of the current vehicle's service life is by savings in fuel and maint. But if I've simply got excess generation capacity, seems like a new EV expense is a costly justification to what may be a mistake (the oversizing of an array).
    You are making it a lot more complicated than it needs to be. An EV and solar generation are a system to harvest energy from the sun and propel you down the road. Cars are as much a personal decision as a financial one. In the past have been changing cars every 3 years because I like the features including safety upgrades. I may lengthen that change because one of my EVs is constantly getting over the air updates so it feels like a new car on the mornings that I get the update message.
    I appreciate the new car bug, and the Porsche Taycan is gnawing at my brain daily, so maybe the question ought to be something like where does one put the cost of the brain gnaw ?
    VW missed their 2018 EV goal by a lot so I wouldn't worry too much about the Taycan being actually in dealers for some time. The Taycan may be another mystery brought to you by the conspirators of dieselgate.
    Not saying it's good/bad, but my guess is a potential PV owner would need to drive a lot of miles/yr. to justify EV cost for the fuel and maint. savings alone over an ICE vehicle, and so, maybe not justifiable for a lot of folks from a cost effectiveness standpoint. However, I certainly appreciate the emotional need that can easily negate sanity with respect to vehicle ownership. I'm sure the makers of EV's feel the same way.
    You are correct. If a car saves you x$ per mile you probably need to drive it enough miles to offset the extra cost. But that is more about whether you should buy a new car or just limp along with an old clunker.It is not unique to the decision to purchase an EV.
    One other thought (and note Ampster - a bit off topic): Suppose EV';s REALLY take off (politics cause gas prices to double/some international B.S. crisis/whatever) with the result being the grid gets pushed past capacity at nite from all the charging taking place. What may/possibly may happen to T.O.U. rates and peak rate times ? Just wonderin'.
    No worries that is an important issue related to the topic of this thread, The capacity issue is another argument used by the anti EV contingent. Take a look at the duck curve and you will realize that there is plenty of capacity late at night and in the middle part of the day because of the large growth in solar buildout in California.
    More data is available at the CAISO site. My view is primarily from the perspective of California because that is where you and I live and because it has the fastest growth in EV sales and solar installations in the USA. If any problems are going to surface, we will probably see them in California first. Better minds than I (including CAISO) have spent a lot of time on that issue and it is really not an issue. My philosophy, like Bruce, is to be net zero so I am hedging my bets in case the policy makers in California get it wrong and the grid is really stressed. In that case you can bet that prices would rise which would make more solar capacity even more attractive. I have already looked at my roof and figured out where I could put another 3 kW of panels.
      • 15036
      #32
      Originally posted by discodanman45
      In California we will find out soon enough about EV charging capacity at night. I believe about 7% of all cars sold in 2018 were EV's in California. Some of the Bay Area cities were over 20% in buying EV's. These numbers will continue to rise and night time charging will continue to grow. In about 5 years we will see changes to TOU rates. We might even see tiered TOU rates to make charging more expensive at night. Right now PG&E's EV-A rate is a crazy deal. I am only producing 75% of my energy needs and it will cost me under $300 per year to cover the remaining 25%. I just hope more people don't catch on to this!
      Tiered T.O.U. rates are with us now. That's so far taking the form of what looks like T.O.U. until you look at the rate sheets and realize that the "credit" for the first 130% (= tier one on the tiered schedules) amounts to laying a tiered rate schedule over a T.O.U. schedule.
      One point: Not all T.O.U. rates for NEM customers are so constructed, but non NEM T.O.U. rate payers to the CA I.O.U.'s are seeing such hybrid rate schedules. I wonder how many know it. Depending on the actual hourly rates and "credit" amounts on the first 130% of a billing period's usage, such schemes can easily negate most of a super off peak rate advantage.
      • Ward L
        • Feb 2014
        • 184
        #33
        Based on the feedback from this forum I have changed my power company rate from a tiered plan to a TOU plan. Like so many things new, it is confusing. I've used SoCal Edison's online rate tool and Excel to estimate my best choice. The SoCal Edison tool predicted a slightly different result than my spreadsheet and I went with my spreadsheet choice. I have switched to the TOU-DA plan. Today is the last day I could have switched to that plan. DiscoDanMan45 pushed me over, thanks Dan!
          • 15036
          #34
          Don't know if you are aware of this or not, and FWIW onlyu, but IOU POCOs in CA will allow you to switch back after changing plans if you find out within 12 billing periods (or less I believe) that the switch resulted in a higher rate being paid for electricity.
          • discodanman45
            • Jan 2018
            • 126
            #35
            I really think it is the best plan for an EV. Just be aware of peak times and reduce use at that time. I have signs in the laundry room with the timez we can do laundry 😁 . Set your car to charge at 10 pm and you will see more credits. Maybe enough to persuade yourself for a second EV. Maybe a $35,000 Model 3!
              • 15166
              #36
              If you haven't already gotten on the waiting list I seriously doubt you will see a Model 3 at that price anytime soon.
              • discodanman45
                • Jan 2018
                • 126
                #37
                They say 2-4 months on the website. I think if you order today it will be within 6 months, depending on location.
                  • 15036
                  #38
                  I'd be careful about quoting charging times. Super off peak, if it exits at all, may be different for different POCOs. Example: Mine starts at midnight and runs to 6 A.M. weekdays and midnight to 2 P.M. on weekends for non NEM T.O.U., with similar but slightly different hours for T.O.U. NEM cust.
                  • discodanman45
                    • Jan 2018
                    • 126
                    #39
                    I looked up his TOU, it starts at 10 PM. That is why I said it 😁
                    Explore Time of Use plans with SCE, designed to help homeowners save by shifting energy use to lower-cost, off-peak hours.
                      • 15036
                      #40
                      https://www.sce.com/residential/rate...ial-Rate-Plans
                      I understand that now that you've stated it in that way. But to me what you wrote looks like a blanket statement applicable to most everyone Guess I just need a little more information to avoid confusion on my part.
                      Also, I notice the link you've provided shows off peak rates starting at 9 P.M. for what SCE suggests for EV owners, or 8 P.M for others, not 10 P.M. as you state.
                      There are also other "rate options" listed on the CSE rate sheet #63179-F (near the bottom) as part of the current (eff. 02/07/2019) SCE sch. D tariff sheets that are a bit confusing as to when or how such options are available or might/not be combined. One of those options is super off peak "10 P.M. to 8 A.M., all year, every day."
                      From what Ward L. writes, I'd bet he's probably already combed through the actual rate sheets.
                      • discodanman45
                        • Jan 2018
                        • 126
                        #41
                        He had until February 28th to enroll in the old TOU-D-A plan. Starting today, those are the new plans. He got grandfathered into a much better plan. It is 10 PM for his plan. See the grandfathered TOU-D-A plan
                          • 15036
                          #42
                          Understood. I stand corrected.
                            • 15166
                            #43
                            And the website I went to shows the lowest price of $42,900. I am sure you can get the price down a bit but without the Fed kickback you will be paying the higher price. I just think the $35k price is long gone.
                            • discodanman45
                              • Jan 2018
                              • 126
                              #44
                              What are you talking about? The website? Just go to Tesla and build one. They are available...
                                • 15166
                                #45
                                I stand corrected. The website I looked at had only 3 prices that started at $42,900 and ended at $60,000. Unfortunately whatever the cost, it is still too high for me.
