SMA String VS Solar Edge with Power Optimizers
I liked my 62 Olds, but finally dumped it for being obsolete. That heavier, plain Jane 77 Olds in front of my array
does 0-60 1.4 seconds faster than that T Bird, faster 1/4 mile, also gets 19 mpg, all on crap 87 unleaded. Yes I
compare cars to the 70s. Bruce Roe
Just to add to the fun
How will the rapid shutdown requirement affect the SMA setup, down the road ?
My understanding is that the SE setup lends itself to implementing rapid shutdown while it will be very expensive to retrofit a SMA setup.
Will existing SMA setup's be grandfathered in and exempt from rapid shutdown ?Comment
SolarEdge has rapid shutdown built in and automatic rapid shutdown built into the new HDWave versions as well (next level).
SMA has a rapid shutdown solution which is costly and cumbersome to implement now but does not meet new automatic rapid shutdown requirements.
SMA did purchase Tigo which makes optimizers.
I suspect that they intend to use the Tigo IP to convert the SMA inverters to more of a SolarEdge type system. This will allow more integrated rapid shutdown (but not by just adding existing Tigo optimizers to an SMA inverter).
generally something does not need to brought up to current code unless there is a change made to it. So yes.
Last edited by ButchDeal; 05-04-2017, 01:32 PM.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
