Announcement
No announcement yet.
Need Some help with this Inverter SCHNEIDER 6.8 KW 48 VDC GRID TIE BATTERY INVERTER
  • Filter
  • #31
    Hi Mike,
    Can the combox set the system time? I don't have the SCP. that is what the programmer use to set the time. The configuration tool can set time too. but I can't seem to find any where could change or set the system time on the inverter with the combox.
    Thank you.
    • #32
      The system time is set IN the combox. That gets broadcast to other devices.
      • #33
        I can't see the system time. Can I see the system time and change it if necessary without the SCP or the the configuration tool with only the inverter and combox in my procession?
        Thank you.
        • #34
          System time setting here:
          • #35
            Well past the point of no return, as of now gotten it yesterday. With respect to the program firmware overhaul, I do have an or more that is associated with the power organization specifically, so I would not out of intensity for the combox and the PC. great to know, however. Much obliged to you.
            • #36
              Thank you Mike,
              Normally under windows if an item has sub-menu, when you double click it, the sub-menu will appear, but this one doesn't. I could click it until new kingdom come it won't appear. because the laptop I use is a small two in one 11.6 inches that I couldn't see or I don't know need to click on the little button on the left to open the sub-menu.
              Thank you again, really appreciated.
