I used to worry about all HVAC functions being centralized, both the propane furnace and
the air conditioner relied on that furnace blower. One failure there and I was SOL. That
problem is gone, with 4 mini split zones, backed up by some substantial resistance heaters
if ever needed. So the blower is never triggered by the central plant anymore.
BUT I have an electrostatic air filter I would like operated regularly. And a little air mixing
between zones could be useful. A brand new blower motor is in place, and the solar PV
provides plenty of energy to run the motor.
SO a new function is tagged onto the central furnace. The blower may be run for a set
time (12 to 60 minutes), and then paused a set time (12 to 120 minutes). This repeats,
unless set to OFF.
Here is the control, which just attaches to the 24VAC thermostat circuit. Next winter will
check it out. Bruce Roe
unless set to OFF.
