Thanks I will look into that
Affordable Charge Controller for AGM Battery
You know you can run a 50w A/C Bulb Direct off battery. If not now you do.Comment
Not really. The amount of amps the panel can produce at it's higher peak is usually the Imp rating.
Typically a 200watt panel would have a Vmp ~ 18 - 19volts which would make the Imp ~ 11amps (200w / 18v = 11.1amps) at best but more likely about 10amps tops.Comment
Ok so my next q is would a quality MPPT controller be more reliable than the elcheapo that is supplied with panel I think it is called a sun lite Chinese made? I was thinking a victron 75/15 ?Comment
You're on the right track in my opinion, victron has a five year warranty and a great reputation. Tons of very cool and Technical looking stuff on their website.Comment
