Affordable Charge Controller for AGM Battery
    Originally posted by photolimo
    I have a 50w light that I am looking to power for 12 hours a day. Thanks for the recommendation.
    You need more of everything as that adds up to 5 cents worth of electricity per day or 600 watt hours.
    To do that you need 250 watt solar panel if using a 20 amp MPPT controller, or 360 watts of panel using a 20 amp PWM controller. Then a 12 volt 210 AH battery, about the size you have now except a new one.
    • Amy@altE
      • 1023
      I have a 50w DC light that I am looking to power for 12 hours a day. It has a voltage regulator on it to help manage the power consumption/brightness. I am hoping to fine tune the battery/panel power this way.
      50W x 12 hours = 600watt hours (Wh) /12V battery = 50aH
      100W panel x 5.5 sun hours in AZ x.6 efficiency = 330Wh of power generated. You need 600Wh. Unless that regulator brings the power use of the light way down, you have only half the solar you need.
      Solar Queen
      altE Store
      • photolimo
        • Mar 2015
        • 22
        Thanks Amy, According to the NREL calculator I get 6.43 average sun hours a day. Is there any reason I should assume less here?
        Is the 0.6 efficiency number based on a PWM based charger setup? I was hoping to squeeze a little more out with a MPPT charger.
          Yeah winter. For a battery system you use worse case month. Any month with less than 6.43 Sun Hours you go DARK without power.
          Only Grid Tied systems use yearly average. You build credits in summer, and use them in winter. There is no credit in battery systems, you live day to day
            Have you read this Stickie? It will answer all your questions. If you use a PWM controller and use 500 watt hours per day your panels must generate 1000 watt hours or a Fudge Factor of 2. If you use a MPPT controller and use 500 wh per day your panels must generate 750 wh per day or a Fudge Factor of 1.5.
            Battery size is based on watt hours used in a day time 5 and divided by battery voltage. So assuming 500 watt hours per day and a 12 volt battery you get [500 wh x 5] / 12 volts = 208 AH.
            • Amy@altE
              • 1023
              .67 is used for MPPT, I was being generous just dropping to .6 for PWM, the folks here have recently convinced me I should go lower.
              As SunKing said, you have to use worst case for sunhours, not average. I see 5.78 sun hours for Phoenix.
              So, using more precise numbers, 100W x 5.78 x .67 = 387Wh in the winter. Still not enough with MPPT. Let's try average, 100W x 6.43 x .67 = 430Wh. Nope.
              430Wh / 50W light = 8.6 hours you can run the light at full power 3 season out of the year.
              Solar Queen
              altE Store
                Stop and think about it Amy. If you use a very expensive 100 watt battery panel (you are forced to use battery panels with PWM) the Specs are:
                Vmp = 17 volts
                Imp = 5.8 amps
                • Use a PWM controller and you have 5.8 amps of charge current right? Perhaps as much as 6 amps on a really dead battery pulling the panel down to Isc range.
                • Use a MPPT controller on the same or a much less expensive GT panel and you get 95 watts (95% efficiency) / 12 volts = 7.9 amps right?
                Which is Greater? 5.8 or 7.9?
                • Amy@altE
                  • 1023
                  Vmp = 17 volts
                  Imp = 5.8 amps
                  As I said, you guys have convinced me not to use .67 for PWM, I just haven't settled on a number yet, because it also takes into account dirt, voltage drop, etc. .6 is still too high, but I haven't been able to jump down to .5 yet (although that's probably where I will land).
                  I was working on the assumption that he already has the 100W panel, and his original question was for a PWM charge controller under $50. If not, and he has a local source for a grid tied panel, and therefore doesn't have to pay $250 to ship it via truck, and is willing to spend $200 for an MPPT charge controller, then heck yah, a 250W 60 cell panel and a BlueSky SolarBoost SB2512i-HV or Morningstar SunSaver SS-MPPT-15L is the way to go.
                  Solar Queen
                  altE Store
                    Assume 100 watts and do the steps:
                    1. Voltage loss between Panels and Controller = 2 to 3%. 97 to 98 watts into controller.
                    2. Controller efficiency PWM at very bet is 67%. 97 in, 65 watts out.
                    3. Battery charge efficiency = 80% down to 52 watts.
                    4. Wire loss between batteries and load @ 1% around 51 watts. Good luck keeping losses to 1% for more than 5 feet to load.
                    50% IMO is to generous if you throw an inverter in the loop. Realistically something lower than 50%
                    • Amy@altE
                      • 1023
                      Oh sure, throw math and logic at me....
                      It makes sense, the truth hurts.
                      Solar Queen
                      altE Store
                        Reality sucks sometimes huh?
                        It really comes down to experience. All that stuff you learned in school is useless academic nonsense. It just gives you the tools to learn when you are out. That is why most teachers teach, they cannot cut it in the real application world. Takes 5 to 10 years of experience to learn the skills on top of education. It sucks, but real.
                          • 15052
                          Looks like the King and the Queen are having a Royal discussion.
                          • Amy@altE
                            • 1023
                            As long as I don't lose my head....
                            Solar Queen
                            altE Store
                              • 5227
                              There is no dispute about the losses of wires, batteries, inverters, etc. But lets
                              review charge controllers for a minute. I don't know much about PWM controllers,
                              since I would never use something with so many negatives.
                              My understanding is the PWM is really an on-off switch, varying the on time duty
                              cycle to limit average power as needed. So if the panel Vmp happened to match
                              the voltage required to match the battery requirement at that time, the efficiency
                              could approach 100%.
                              In fact battery charging voltage varies a lot, and panel Vmp varies quite a bit with
                              temperature, so they hardly ever exactly match. To the extent they mismatch,
                              efficiency is lost. There might also be a series diode loss to prevent night discharge,
                              which will be more damaging in the lower voltage circuit. The diode loss can be
                              avoided electronically at some cost.
                              MPPT controllers manage to always operate panels at the best possible point for
                              conditions, matching them efficiently to the battery. They have the additional
                              advantage of being able to operate at an uncritical, higher input voltage, reducing
                              wiring losses. Is this all accurate? Bruce Roe
                              • Living Large
                                • 910
                                You're very grounded, from what I have seen. Be-dum-dum
