Affordable Charge Controller for AGM Battery
For the low voltage panels like a 100 watt panel. expensive MPPT is not going to be efficient. I also heard about MPPT not being efficient with the smaller panels but i had to try it for myself.
As an example I had a 120 watt kyocera panel (max voltage i saw was about 21 volts) , I tried it with both a 20 amp pwm wincong controller (20 dollar) and a 20 amp mppt ecoworthy controller (102 dollars), hooked up to my giant 145 ah agm battery.
with mppt I get about 6 amps
with pwm I get about 7 amps
On the other hand with a larger 240 watt sharp panel (max voltage i see is 36 volts) and same battery.
with mppt i get 12 amps
with pwm i get 7 amps
You can get a cheap 10 amp wincong controller, they were extremely reliable for me for the low price. Just make sure you get a 90 volt 30 amp LED combo meter and connect between you controller and battery so you know exactly how much amps/voltage is going into your battery instead of relying on blinking lights. The wincong works great on agm batteries, thats the only batteries I use.
Only get an mppt is you plan on buying another 100 watt panel, connecting 2 x 100 panels together in series will get you the over 30 volts of electricity that the mppt needs.Comment
You need to get a real MPPT controler and try again. You got robbed buying an Ecoworthy controller. Any true MPPT controller Output Current = Panel Wattage / Battery voltage.As an example I had a 120 watt kyocera panel (max voltage i saw was about 21 volts) , I tried it with both a 20 amp pwm wincong controller (20 dollar) and a 20 amp mppt ecoworthy controller (102 dollars), hooked up to my giant 145 ah agm battery.
Here is your proof. With any PWM controller Input Current = Output Current. A 120 watt Kyocera panel Imp = 7 amps. If it were a real MPPT controller with their claimed 96% conversion efficiency would be [120 watts x .96] / 12 volts = 9.6 amps. Your 240 watt panel should be pumping 17 to 18 amps.
Rather you want to admit it or not, you got screwed.MSEE, PEComment
Here is an interesting project from an EE in India. His first attempt is a PWM but version 3 is MPPT. What really caught my eye is that it has an integrated Ah/Wh meter.
ARDUINO SOLAR CHARGE CONTROLLER (Version-1): [ Play Video ] In my previous instructables I described the details of energy monitoring of a off grid solar system.I have also won the 123D circuits competition for that.You can see this ARDUINO ENERGY METER. Finally I post my new version-3 charg…
ARDUINO SOLAR CHARGE CONTROLLER ( Version 2.0): [ Play Video ] One year ago, I began building my own solar system to provide power for my village house. Initially, I made a LM317 based charge controller and an Energy meter for monitoring the system. Finally, I made a PWM charge controller. In Apr…
ARDUINO MPPT SOLAR CHARGE CONTROLLER (Version-3.0): [ Play Video ] Welcome to my solar charge controller tutorials series. I have posted two versions of my PWM charge controller. If you are new to this please refer to my earlier tutorial for understanding the basics of the charge controller. 1. Versi…
What do you all think of his work? I wonder how one could improve on its design?Comment
Last year there was someone on the Forum that was building a home in Alaska or North-West US that was also dabbling in an MPPT equipment design. He may have even gone the route of using Kick-start to help fund his design. I haven't seen any new info on it.
I am sure there are many table-top scientists/engineers working on a "new" equipment. But like anything new it will be an uphill battle to get their device to market if the big guys put any roadblocks in the way.Comment
That moron was Electrocudas. He has been ran off all solar forums. He showed up on Mike Holt's site and got Bar-B-Qued and banned in a day. He also showed up on a DIY EV Forum, lasted 3 days with 200 pages of blather from him and got roasted before they pulled the plug. The guy is an excellent Troll, I have to give him that. But on Mike Holt and the EV forum is full of jerk engineers like me who blasted him. Poor guy does not even know Ohm's Law or basic formulas any first year student would know. Pretty comical.MSEE, PEComment
I don't see a coil on that drawing; there need to be some reactive elements in a buck.Here is an interesting project from an EE in India. His first attempt is a PWM but version 3 is MPPT. What really caught my eye is that it has an integrated Ah/Wh meter.
I don't know about his software, but that breadboard reminds me of something I had to
help high school students with. Their 8080 didn't work, because of inductance in the
reference network (ground). Switching circuits need a very low inductance ground
plane reference (unless totally differential), and it just gets worse as the power level
goes up. Bruce RoeComment
I would be nice if you had something positive or constrictive to add to this discussion.That moron was Electrocudas. He has been ran off all solar forums. He showed up on Mike Holt's site and got Bar-B-Qued and banned in a day. He also showed up on a DIY EV Forum, lasted 3 days with 200 pages of blather from him and got roasted before they pulled the plug. The guy is an excellent Troll, I have to give him that. But on Mike Holt and the EV forum is full of jerk engineers like me who blasted him. Poor guy does not even know Ohm's Law or basic formulas any first year student would know. Pretty comical.Comment
OK then he's on the right track. I didn't click all the right places. Can't see his wiring,
but with that scope (better than I had in the 60s) he should eventually figure out the
issues with parasitic elements. My switchers look like a copper box surrounding the
elements.
Those toroid cores get pretty expensive at power levels. Bruce RoeComment
hey guys new to this.if I wanted to charge a 130a/h agm with a 200w panel with max voltage of18.3 v what would be the perfect controller to use.Comment
OK, so that's about 12 amps the controller needs to handle.
here's 2 name brand models:
Morningstar SL 20L 12V $105
or
Morningstar SK-12 SunKeeper 12 Amp PWM $85Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
