You are confusing MANY concepts and situations. AC vs DC does NOT matter in this situation. Running something during the day via AC or DC is more efficient than running at night. The difference is NOT AC or DC but the fact that you cycled the battery. You have losses in charging the battery and then in discharging the battery.
So lets do APPLES and APPLES here and toss out Solar All together. You have a battery and an appliance. You differences are going to be minor. Though it will be considerably cheaper to go AC will less wire lose, smaller wire (due to higher voltage), cheaper switches, easier to keep the battery in a safe location with vent and battery box.
And here is the kicker. AC appliances are cheaper and there are more of them, on top of that and this is the real kicker here, for the same money in purchasing an appliance you almost always can get a more efficient one that is powered by AC....
If you do a benefits analysis of AC vs DC there are almost ZERO benefits to using DC and a hell of a lot of negatives for using it.
Or you can continue to dream up using multiple distributed batteries, DC distribution, costly DC appliances (with built in inverters), multiple charge controllers, and solar arrays to charge the multiple batteries.
