Most Popular Content
24 volt system help, newbie
With an average of 6 hours full sun and a desired production/usage of 8kwh/day what is the most economical/best 24 volt set up?
I wanted to stick with 24 volt because I can get new panels for 82 cents/watt and I think I'd be able to start it small (just run my .4kwh/day chest fridge) and increase its size to suit my long term needs of ~8kwh/day.
Thanks again!Comment
I'll most likely abandon the distiller and make a solar still, that 3kwh/day could go to a little tv instead.Comment
They also make a small travel tv with an internal battery but it might be easier to stream tv shows on your computer using a satellite up-link.Comment
I'll most likely build a solar oven into the south facing wall. I'll also build a distiller which will fit into the solar oven, there's a diagram in one of the Michael Reynolds books I have.
I'll still want the induction cooktop for some quick eggs in the morning etc. 2kwh/day on the cooktop would be over an hour at full use. That'll mostly never happen. My 8.5kwh/day is really a MAX usage.
Any thoughts on the set up?
Thanks!Comment
With an MPPT cc it wouldn't matter what solar panels I purchased so I could use 27 volt panels to charge a 48 volt battery?
If so, would it be cheaper/same/more expensive to do a 48 volt system instead of a 24 volt? Where you're looking to produce 8.5kwh/day with 6 hours avg sun?
Thanks everyoneComment
Thanks everyone
If you hooked up the panels in series you will increase the voltage (such as 2 - 27volt panels = 54volts) to the charger input. For that matter the higher voltage output panels end up to be less expensive per watt than the lower voltage panels.
Also most MPPT chargers have a much wider voltage input range than PWM type as well as multiple output voltage settings including 48volt.
By using the 48volt battery system you will:
1. reduce the amperage allowing you to use smaller wire size
2. give your batteries a better life by running them in series instead of parallel.Comment
I still think they are pretty cool looking. I had entertained the though of building a dome type home on my retirement property back a few years when the hurricanes where beating us up. I actually found a number of places that sold everything from full cast concrete to engineered panels that assembled into a dome. The HUD ratings had is survivable up to Cat 4 storms as long it was above any type of storm surge.Comment
Extremely flawed assessment, and the truth will surprise you. If you go with a solar off-grid battery system you will be emitting more CO2 vs buying it from the POCO not to mention the electricity from a battery system will cost you around 10 times more than buying it for the rest of your life. So if you are under the impression you are going to save money or the earth forget it as it is not remotely possible.MSEE, PEComment
If you demand 8.4 Kwh/day, you have no choice to go with a 48 volt system period in your area. Higher voltage is less expensive than lower voltage.
Your system to meet 8.4 Kwh minimum requirement is:
- Panel Wattage = 2600 watts
- 48 volt Battery Capacity = 875 Amp Hours
- MPPT Charge Controller = 50 amps
- Maximum Inverter Wattage supported = 2600 watts or smaller
- Minimum Generator = 7 Kva
- Minimum 48 volt AC charger = 100 amps.
MSEE, PEComment
Only if you burn them to stay warm.
domes can be cool, specially if they can be sunk into the ground a bit. I built a truncated icosahedron (pentagon floor plan, triangle walls/roof) on the edge of a cliff one time back in 80s. Amazin how much room there was in there with only 140 sq ft of floorspace.Comment
hahaha.... I never thought of that, burning, if they would be a hazard in/near a forest fire.
I think I can keep my electrical footprint down to only needing about a 5kw system to handle everything but have to work out the numbers and it is still a few years off.Comment
