With 950W of solar which you will at best case get 70% of x say 3.5 hours a day of insolation during the winter that only accounts for 2150 watt hours a day. The rest would need to be made up by the turbine. At 500 Watts of Turbine assuming you have the wind 24/7 to produce much(very unlikelymore like about 1/4 that amount) that will contribute another 3000 watt hours a day.
If you are using 7000WH a day add it up and you will see you are in a deficit position. Be wary of what a wind turbine will produce.
At rated power the wind needs to be at about 25 MPH if less than the output will be the inverse of the square of the rated output
