View Post
Take note of what the description is telling you in the TEST REPORT. What Simon does not understand the output never goes to 0% because the circuitry uses 10 ma from the output. Anyone who has electronic design experience knows you cannot power anything with ZERO VOLTS, AMPS & WATTS. Thus the output never goes to ZERO. That tells you Simon Mathews is a pretender.
I use to work in Telecom for 30 years for a major telco and have installed thousands of DC battery plants. After being laid off in 2003 I started my own engineering company doing the same work for more money, an dhave built over 200 Off-Grid Battery systems at remote cell sites, and some large grid tied systems for Walmart and DOD.
Back to Current Sources. Makes no difference is the Current Source is from a Voltage Source or Solar Panel, if you open the load, the voltage goes to the source voltage. A Solar Panel is a Current Source and the controller has a huge capacitor at its output. Your own eyes have seen what happens when the battery is disconnected. Your eyes are not lying to you.
