"You have been given all your options. Pick one." What is this, "Kung Fu"?
The way I understand it from Genasun, when charging goes to 0A, the GV-5 goes to panel voltage for a couple of seconds before it settles into CV. If the GV-5 has to go to 0A to keep a drop-in-replacement battery at CV voltage, then even though the battery doesn't disconnect like the Bioenno battery does, it wouldn't eliminate the problem. I'll get a drop-in battery and experiment at some point.
Here's what Elecraft says about over voltage:
I've decided that I don't want to try floating any battery with this controller. Even with a completely compatible battery, an accident as simple as kicking a battery lead loose would fry my radio. In fact, although it's probably overkill, I might not float any battery with any controller with this radio in the loop.
When I get the controller, I'll experiment with a resistor at the load terminals. I wouldn't connect one permanently, though, because, as you said, it would use up the battery a lot faster.
The absolute maximum input voltage is 15.0VDC. Any higher than that, or any voltage transients, will likely damage the PMOS switching power transistor that turns on the rig, and the PA transistors. Such damage would not be covered by the warranty.
So you need to do whatever is necessary to prevent more than 15.0VDC from ever being presented to the rig, either when it is OFF or ON. We have seen KX3s damaged if this happens.
It could be done by adding an external voltage regulator between the rig and the battery/solar panel charger, or some type of transient voltage suppressor, or by using a different solar controller that never allows more than 15.0VDC across the battery.
