You just make all this stuff up, exactly the same as you made up what you thought was inside a Bioenno battery. The link you gave to the "TI LM5019MR 100V, 100mA Constant On-Time Synchronous Buck Regulator" in post #132 has nothing to do with MPPT controllers, it is a low current buck mode power supply which only supplies 100mA, hardly suitable for an MPPT controller. It has nothing to do with the TIDA-00120 that you mention in the above paragraph. The TIDA-00120 is not a full MPPT controller, it is what is known in the industry as a "reference design" provided by TI to try and sell their products. Sunking you have no idea how many MPPT controllers out in the market use the TI chips.
In the TIDA-00120 documentation one of the entries in a table shows the output to the battery at zero current which is what you were saying was impossible in previous posts. If the output voltage rises above the programmed output you don't know if the MSP430F5132 controller IC in the TIDA-00120 turns the switching FETs between the solar panel and the battery completely off. In this case the controller electronics would draw the 10mA from the battery and the capacitors in the output circuit of the TIDA-00120. I have never said that the voltage goes to zero. I have said that the current goes to zero. FWIW the MSP430F5132 is not a specialised chip but a general purpose microcontroller not unlike the Frescale 68HC12 that I use in my MPPT controller. The control of how much of the time (%modulation) the switching FETs that connect the solar panels to the battery  are on if totally controlled by software running on the microcontroller.
Sound like you are a Systems Integration Engineer. From what you have written in the past it looks to me like you might know how to connect solar panels to a solar controller to Lead Acid batteries but don't understand how the electronics work.
If the controller reacts quickly enough and disconnects the output from the source the output voltage will not go to the source voltage. The huge capacitor will actually try to stop the output voltage changing, that is what capacitors do. I would say that to save space and weight that the GV5 doesn't have a very large output capacitor.
				Take note of what the description is telling you in the TEST REPORT. What Simon does not understand the output never goes to 0% because the circuitry uses 10 ma from the output. Anyone who has electronic design experience knows you cannot power anything with ZERO VOLTS, AMPS & WATTS. Thus the output never goes to ZERO. That tells you Simon Mathews is a pretender.
				I use to work in Telecom for 30 years for a major telco and have installed thousands of DC battery plants. After being laid off in 2003 I started my own engineering company doing the same work for more money, an dhave built over 200 Off-Grid Battery systems at remote cell sites, and some large grid tied systems for Walmart and DOD.
				Back to Current Sources. Makes no difference is the Current Source is from a Voltage Source or Solar Panel, if you open the load, the voltage goes to the source voltage. A Solar Panel is a Current Source and the controller has a huge capacitor at its output. Your own eyes have seen what happens when the battery is disconnected. Your eyes are not lying to you.
