Imagine if you had just bought a solar system in Iowa..
  • rebar
    • Jul 2011
    • 43
    And then the utility company pulled the rug out from under you..
    What's Happening? The Iowa Utilities Board (IUB) recently accepted a proposed rule change from Alliant Energy, one of Iowa's two major electric utility providers. This new ruling will drastically change how net metering works in Alliant's service territory and will reduce the financial viability of new solar installations for both residential and smaller commercial customers. Alliant Energy's new tariff takes effect on April 1st of this year and will impact Alliant's 488,000 electrical customers across Iowa.
    Are other net metering states going to pull the rug out so to speak?
    In a perfect world where everyone had solar and the utility companies didn't need to generate electricity because they could store enough to make it through the night. Or they had figured out how to transmit electricity efficiently from the opposite side of the world. How would the utility companies maintain the grid? Is this the limitation of net metering and why utility companies are changing the rules?
    Thanks
    • 5209
    Some may need to make it through the night, but my net metering needs to make
    it through 4 seasons. My contract runs another 14 years, but rule changes can
    easily make net metering impractical for consumers. Some states have
    already done so, but can also be pressured to restore it. Bruce Roe
      • 15017
      Welcome to the real world where there's no guarantees. CA investor POCOs and the CPUC reduced residential PV cost effectiveness for new installs by about 25 % a couple of years ago and effectively by 15-25 % for all PV users by changing TOU rates and times and other measures. Other states/governing bodies have done similar to remove what some think is an unfair burdan placed on POCOs and their non PV customers by the PV industry and their customers.
      I'd think of it as gov. mandated but temporary incentivization to get a fledgling PV industry started, and a situation that was never intended to be permanent in spite of what some may think.
      Think of it as the party for PV coming to an end. Now, it's time for PV to stop dragging off the public tit, grow up and stand on its own. In the end, alternate energy as a way to carry its share of the energy generation load will be better and stronger for having been cut loose.
      By way of some analogy, I learned how to ride a bike faster, better and safer than those who used training wheels.
      • NEOH
        • Nov 2010
        • 478
        I think it is Alabama, where you PAY the Electric Company a $5.00 FEE per kilowatt of installed Solar Panels, every MONTH they are connected to the Grid !
        "Residential Break-even" under those terms is never ...
          The end result could be a death spiral for those utilities. It may take a while and the respective states may have to bail them out along the way.
          What they are doing with those pricing mechanisms is incentivizing load departure. For people that can afford it, it means self consumption of solar enhanced by battery storage. In many jurisdictions the user is free to do anything he wants to do behind the meter as long as it meets the building codes. I am not talking about disconnecting from the grid or going off grid.
          • khanh dam
            • Aug 2019
            • 391
            Isn't net metering only important if you generate more electricity than you use (not most installs)?
            I guess if one uses more electricity at night instead of during the day, it could be a unbalanced situation. do not quite understand what is happening?
            this article states the combination of car battery tech with residential pv could really hurt utilities in the future, probabaly their way to slow the damage.
              No, it is more about when you use power. If you only use electricity when the sun shines you can self consume and it doesn't matter.
              Yes, that is a real possibility.
                .... this article states the combination of car battery tech with residential pv could really hurt utilities in the future, probabaly their way to slow the damage.
                Not going to go far, car batteries are too dang expensive to have one in the car, and another on the wall.
                The "Prius as a UPS" is likely the best scenario. Plug the smart car into the smart charger and let the utility manage the charge and discharge at night, as long as they leave you with 90% of battery in the AM. And likely to accelerate the car battery's demise, not covered under warranty.
                • rebar
                  • Jul 2011
                  • 43
                  Thanks guys..
                  The majority of my utility bill at my bug out property in Iowa is propane during the winter. I was wondering if solar could be used if I outfit the house all electric appliances since I have a acre of space. I would have to generate more than I used and then buy it back at night imo. But without net metering it would be even more expensive than propane to heat. And also the fact winter solar produces less than summer make it a pipe dream.. Oh well..
                  • khanh dam
                    • Aug 2019
                    • 391
                    using solar PV for heating is typically a bad idea. Mitsibushi makes some cold weather heat pumps, you might investigate that, not sure if it would be cheaper than propane in your climate.
                      at your site in Iowa, do you get a lot of snow that would cover panels in winter ? Clear skies ? Cloudy skies. If it was simply clear and cold, and not a lot of snow to shovel off the PV panels, it might be worth looking into.
                      • khanh dam
                        • Aug 2019
                        • 391
                        It is almost always cheaper to buy more insulation in the long run. My local energy company has a home effcicency program, they cam out with one of those infrared cameras and showed me where my ceiling lights and speakers needed more insulation. I bet your local utiity company has a similar program.
                        • rebar
                          • Jul 2011
                          • 43
                          Exactly.. Super insulated Shouse where the barn is. I wish the mobile home was gone, but GF lives there now.
                          View from mobile home
                          • rebar
                            • Jul 2011
                            • 43
                            HF669 and SF583 would charge solar owners more each month just because they have solar panels.
                            Ask your state representative to oppose SF583 and HF669. This legislation would allow MidAmerican and Alliant to put expensive charges on your bill if you own solar panels. What's more, this legislation would create complex billing schemes. The only purpose of this legislation is to discourage anybody from putting solar panels on their property. Even worse, the utility would not pay a fair amount for the electricity that is delivered to the grid.
                            I even wrote my legislators and I don't even own solar. I'm appalled! You folks should to, because this may happen to your state if it happens here.
                            https://www.sierraclub.org/iowa/blog...f669-and-sf583
                              • 5209
                              If you are building a house, nothing wrong with super insulation. But converting an older
                              house to that level of insulation will be extremely difficult. Those of us in a house are
                              not likely to tear them down. Still you will need some energy to cover losses. With
                              PV solar you can cover that loss and get to zero net energy use. But with the older
                              house the best trade off is perhaps a lot more solar and a lot less insulation.
                              The only practical way to convert your summer collected PV energy to winter heat, is
                              net metering. A useful measure is that a gallon of propane is equal to about 27KWH
                              of electricity. That means a 10 cent KWH can directly compete with a $2.70 gallon of
                              propane using resistance electric heat. With the prop suppliers desperately trying to
                              export as much as possible and create an artificial mid winter price twice that, you
                              are better to electrically heat.
                              But if you use a heat pump with negative temp capability and a COP of 3, you can
                              compete with $0.90 a gallon propane. And of course, air condition very cheaply with
                              the same equipment. Still this falls short of natural gas, for now. Bruce Roe
