Very useful advice! I didn’t realize unplugging electronics could save that much energy. I’ll definitely look into a programmable thermostat and better window shading.
energy saving tips
Sounds great! But I'm surprised that you didn't know about the potential savings of unplugging appliances, when you seem to have quite a bit of knowledge in other areas:
I guess it just goes to show that even very knowledgeable folks can learn something new.It’s likely an intermittent bypass diode issue in the panel, not the microinverter. When a diode weakens, output can drop to about two-thirds, then return temporarily depending on heat or conditions. Since Enphase shows the micro as normal, the panel itself is the suspect, often requiring replacement if it worsens.Comment
Sometimes it comes down to understanding the littles things that most know about that can confuse the educated. it is called common sense.Comment
