energy saving tips
  • EnergyC
    • Aug 2025
    • 6
    #76
    Very useful advice! I didn’t realize unplugging electronics could save that much energy. I’ll definitely look into a programmable thermostat and better window shading.
    • sdold
      • Jun 2014
      • 1490
      #77
      Sounds great! But I'm surprised that you didn't know about the potential savings of unplugging appliances, when you seem to have quite a bit of knowledge in other areas:
      It’s likely an intermittent bypass diode issue in the panel, not the microinverter. When a diode weakens, output can drop to about two-thirds, then return temporarily depending on heat or conditions. Since Enphase shows the micro as normal, the panel itself is the suspect, often requiring replacement if it worsens.
      I guess it just goes to show that even very knowledgeable folks can learn something new.
        • 15207
        #78
        Sometimes it comes down to understanding the littles things that most know about that can confuse the educated. it is called common sense.
