that's easy.. 7600 it is
Which panel and system would be best for us? How to decide btw competing quotes.
This is what I have been repeatedly told as well. I pointed out that it doesn't make much since. if they are just going to do full inverter trade ins then why not allow other inverters, particularly the SE6000 and just give a little less credit.
The upgrade path from the base 7600 to Storedge isn't clear. For now, SolarEdge offers a $608 credit toward the purchase of a Storedge inverter when trading in a 7600A base model.
https://www.solarpaneltalk.com/filed...3&d=1492186097
(Courtesy of DanKegel)
No good reply other than they hope to have the more direct upgrade path soon with DC disconnect box swaps.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Production quoted for my roof (east facing only):
21 - E20 - 327 w/SolarEdge = 10,140 kwh/yr or 845 kwh mo
21 - E20 - 327-C-AC = 9,665 kwh/yr or 805 kwh mo
generally speaking, why is efficiency better for SolarEdge Optimizers? (if correct). I don't know which specific model SolarEdge optimizer it is...
SolarEdge equipment has a higher efficiency than almost all other inverters.Production quoted for my roof (east facing only):
generally speaking, why is efficiency better for SolarEdge Optimizers? (if correct). I don't know which specific model SolarEdge optimizer it is...OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
I got quoted $1340 from Tandem Solar. Price on their webpage is slightly higher ($1347.50)Last edited by sensij; 05-22-2017, 05:23 PM.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Plus installation and the finger point hassle between vendor and installer if things go wrong.Comment
for comparison-- I understand P400 optimizers are about $71 each..., and then I would need t buy SE7600.. not much price difference, but optimizers are more efficient (no shading).. tks
I was commenting on your statement about being able to add a switch to run the home on solar without the grid and how inaccurate that is.
You keep calling them edge optimizers. The company name is SolarEdge and they are just optimizers or SolarEdge optimizers.
Enphase micro inverters run about $130 to $150 each. but you also have an expensive cable that is required so add another $20 eachComment
