    • 15051
    #436
    Bruce:
    Can you tell me a bit about your inverter setup ?
    I'd like to know which arrays feed which inverter.
    Thank you.
    J.P.M.
      • 5223
      #437
      Bruce:
      Thank you.
      J.P.M.
      Each array has strings that equally feed both inverters. If marked it would look like checkerboard.
      Originally the east and west sides were not mixed, but there were shade situations where one was
      clipping but the other was under peak. Checkerboard conversion cured that. Bruce
        • 15051
        #438
        Thank you.
        I'll rate each array by assigning inverter capacity as [(15/35) * array size] and use a DC/AC ratio of 2.333 for each array unless advised otherwise.
        J.P.M.
          • 5223
          #439
          So it was 17 F below zero this morning, a tour revealed the 6 heat pumps
          were keeping up and performing as intended in 2 buildings. I believe
          heating capacity at best is about 9 tons, that is degraded quite a bit at
          this temp. The "just right sizing" people would say I have way too much,
          but I say this allows a couple things. First I never need to switch to
          auxiliary heating, although it still exists here. Second no single failure
          (like a furnace blower motor) can cause a desperate situation, spare
          capacity will carry me through till I get around to repairs in summer.
          Cost was quite minimal when bought on the internet and DIY installed.
          Well into the 11th winter things are quite stable, system repairs amount
          to 3 burned out electrical connections and one panel hit by a tree. And
          I did have to scrape sap off some panels till that tree was removed. So
          it may be the coldest day of the year, but the spinning disc shows with
          sun the cold panels are collecting more energy than I am using. I see
          about 4200 kWh energy still in reserve, but days will soon be here when
          I can make as much as I uses again.
          One thing the extra energy has made possible, is running the big
          electronic air filter nearly a third of every hour. Looking at the particles
          (or rather the lack of them) in a beam of sunlight shows a drastic
          reduction in solid stuff floating int the air. Of course the particle charging
          method used works no matter how small the particle, not just the ones
          bigger than a mechanical screen. And maintenance ia way less as well.
          Wish I had done this much earlier in life.
          I am realizing the E-W array design has more advantages than I first
          planned. It takes an absolutely minimum of snow cleaning effort, often
          none while I am clearing the S facing panels. It basically operates all
          year with no need to worry about changing tilt. I can collect a better
          ratio of energy to unshaded space. And the cost of material for my
          6061 aluminum ground mounts has increased so much (way more
          than the panels mounted), it makes economic sense to mount twice
          as many panels, facing opposite directions. The original objectives
          were to maximize energy collected with a 15KW peak limit, and double
          output under clouds.
          Bruce Roe
            A lot of wire insulation loses too much of its flexibility at -20F to be reliable. Finding an insulation with the right combination of sunlight resistance and flexibility could be interesting
            I got a spool of 10ga wire labeled "locomotive cable" years back that had insulation that was supposedly flexible down to very low temperatures, sunlight and oil resistant and good to 600 volts. It's hard to find though.
            • organic farmer
              • Dec 2013
              • 682
              #441
              When I was making the cables to fit between the batteries of my bank. I considered the wattage rating of the cables. Some of them needed to be bent into weird shapes. But it was all done during summer weather. and those cables will never be bent to a different shape ever again. What are you doing with wire that requires it to be bendy flexible in negative temps?
                • 5223
                #442
                Memorial Day was sunny and long, how about 155 kWh produced by my
                15kW inverter plant in a day? Bruce Roe
                • Mike 134
                  • Jan 2022
                  • 444
                  #443
                  I think you're metering is broken. 15KW every hour for 10 hours. Unless you have trackers on all the panels.
                  • DanS26
                    • Dec 2011
                    • 1001
                    #444
                    I got 121.6 kwh on Monday from the same size 15 kW inverter plant. A few clouds around but my DC to AC ratio is only 1.54. Lots of clipping mid day.
                    Over 13.5 years of production now stands at 309.9 mWh with zero downtime for both panels and inverters. Those two Fronius transformer based 7.5's just keep chucking along....knock on wood. The Kyocera 235 and 245 panels look like brand new but they are degrading ~0.7% per year as expected.
                      • 5223
                      #445
                      I actually have a pair of 7.5 kW systems, like DanS26. I doubt they are both
                      broken, they tend to agree very closely. You may have seen my past graph
                      showing the inverters in clipping for over 8 straight hours, my record is
                      157 kWh in a day. After 12 years, I conclude clipping does not shorten the
                      inverter life. They are capable of 277V operation, so my 240Vs gives them
                      margin against voltage. Bruce Roe
                        • 15051
                        #446
                        Mike: Bruce is just way over paneled for the inverters he has. He believes it's cost effective to have inverters spend a lot of time in clipping. He and I beat that to death for several years.
                        He may have the only array(s) that are visible from low earth orbit.
                        • DanS26
                          • Dec 2011
                          • 1001
                          #447
                          When I erected my shoulder array (ie east/west orientation..see profile pic) my objective was not to optimize production since I produce around twice what I consume. My goal was to optimize my plant in relation to my 200 amp electrical service. I was maxed out and did not want to upgrade to 300 or 400 amp service due to expense and hassle that change would entail.
                          So I opted to maximize production in morning and afternoon to more efficiently use existing plant. But that being said I realize that just adding a standard south facing array would have harvested more power. I think now i just liked the esthetics of the shoulder array and sort of ignored the power dynamics.
                          This summer I am going to add another piece of art to this project. I'm going to build an Analema with my three grandsons. The gnomon will be 12 feet tall and aligned with the north south axis line of the shoulder array. Solar noon and clock noon on the first day of each month will be identified and staked. Also the equinoxes and solstices will be noted. The Analema shadow points should be around 20 feet in length. It should be a learning experience for everyone.
                            • 5223
                            #448
                            An Analema should be a fun project, about all I have is a sun dial. It gives sun time,
                            not daylight saving time. I did try to get components for a ground level sun dial
                            some 20 ft across, but failed. You would stand on the marked spot to cast the
                            time shadow.
                            Much agree, one view of the E-W array, is that doubled panels make much better
                            use of every other part of the system, from the panel supports, and everything else
                            to the connection to the AC net meter. Even more so for us under frequent clouds.
                            With a pretty leaky 70s house + water to heat, there is not much left over from
                            29,000 annual kWh production. Bruce Roe
                            • solar pete
                              Administrator
                              • May 2014
                              • 1859
                              #449
                              Hi All,
                              I'm not scared of inverters clipping either Bruce, I'm sure JPM must realize if you want max production in the winter months you put as many panels on the inverter as you can or are allowed too. As always thanks for the update Bruce.
                              Some may have noticed that we have a link to the solarreviews.com (our site sponsors) calculator again, we had it on a few years ago but they took it off when google started to not like forums as a source of info, I think they are just trying an experiment to see if that's still the case. If things haver changed, I hope they have as we will get some IT department time to spend on SPT to fix up or improve a few things, cheers
                                • 15051
                                #450
                                Originally posted by solar pete
                                Hi All,
                                Pete:
                                Respectfully, I don't know any such thing.
                                But I think I do know or would at least suggest that maximum production, as a concept must be defined by the user/owner/operator as (duty required).
                                For example, one definition might be to have a string inverter operating at or close to its maximum rating for the maximum number of daylight hours over a certain period.
                                Or, have a string inverter operate as close to its rated output at certain times such as at times of high T.O.U. rates.
                                Or, as seems to be the case for Bruce and Dan, If one wants to prioritize max. production out of a string inverter as a design goal over the course of a winter day for some reason(s), orienting the array for max. clear sky winter production would be a good start (which Bruce has not done), and then sizing the inverters such as to cause inverter clipping under an hourly average winter irradiance level until the inverter clips for as long as (or when) you want to ensure it will clip while in the end meeting some goals, whatever they may me.
                                NOMB or concern, but I've never seen the logic behind such actions as being the most financially sound way of proceeding.
                                All that said, I'm aware of, or at least I can conjure up lots of applications that require more generation at certain times than others and that such situations may and probably will require array orientations and other design decisions and actions that will result in less than maximum available panel output and/or increased per kWh production costs. But, like putting the cart before the horse, sizing the inverters before the arrays without careful analysis of alternatives seems backwards to me.
                                I'm also aware that some applications are inverter size limited by POCO or AHJ requirements.
                                In such cases, the COST of complying with those requirements can sometimes be minimized optimizing array orientation(s) to the greatest extent possible and (unfortunately) also perhaps biting the bullet and realizing that to get what you want under the imposed constraints may cost more than you're willing to spend. See the "I want what I want" logic below.
                                I say (write) that because I'm also aware of something called solar process economics where one (usually) common goal is achieving all the other project goals in the most cost-effective manner as possible as defined by the person or organization paying the bills. I have yet to come across anyone or any organization that does not want the most bang for their buck to achieve the stated and defined project goals or requirements whatever they may be including whatever the imposed constraints on the project may be (while still keeping in mind that "costs and logic be damned, I want what I want" can also be a project goal.
                                I've seen that thinking 1X/awhile and usually manage to avoid being involved in such projects as a matter of policy. Somebody always gets it in the shorts on such projects.
                                Anyway, if I want maximum production and maximum cost effectiveness from a system (and not just the maximum duty cycle out of a string inverter) during winter months, or perhaps over the course of a defined "winter", I'd first define my production requirements and schedule and other goals by hour, time of day, day, week, month or season as required and then size and orientate the array(s) to meet that duty cycle using a design model or models, and then size the inverter(s) with an output (AC) rating to meet about 90% or so of the STC rating of the array(s). Iterate the design a few times to convergence and get some preliminary cost estimates. I suppose the inverters can always be undersized but after sizing the arrays to meet the project goals I don't see the logic in that.
                                Pete, I'm not afraid of under-sizing inverters, arrays or anything else to meet project goals provided safety concerns are the first priority.
                                But if good and cost effective design are the goals and I want maximum production out of an array in the winter, or any other time, I'm sure I realize that over-paneling (or maybe better said/written as inverter under-sizing) is not the best use of materials, capital or design capabilities as a first choice and probably not the most cost-effective way to meet a production goal.
                                IMO only, that's not necessarily good or even safe design.
                                It's all about good and thoughtful design, defining project goals while keeping within imposed constraints.
                                Do you want system production at a certain level, or a string inverter that operates at or close to its maximum capacity?
                                Seems to me one answer might be the one that gets as close to the desired effect in the safest way possible for the least long-term life cycle cost is the way to at least start.
                                But that's the way I was taught and learned engineering.
                                As usual, take what you want of the above. Scrap the rest.
