solar system for shed
You are correct. There really shouldn't be an issue with a 120v bulb on a 12v circuit. Possible Mike was focused on the other way, 12V on a 120V circuit when he posted the warning.
Of course not. My question was with regard to the bad things that could happen with a 120 volt bulb on a 12 volt circuit. As far as I have experienced, nothing bad will happen except it will not be very bright. Hardly a safety issue compared to plugging in a 12v bulb into a 120v circuit.Leave a comment:
Have you ever screwed in a 12V bulb on a 120V circuit? Not pretty.
I just wish the 12V bulbs has some type of inhibitor to keep them from being used on higher voltage circuits.Leave a comment:
I use 300 Watt 120 volt bulbs to bleed the voltage on 8 volt DC battery modules. What have I missed?Leave a comment:
Yes you can use them. But you NEED to be VERY careful, not to let anyone put a 12V bulb in a 120V socket, or a 120V LED bulb into a DC socket, either mistake can end badly.
I have a few regular light bulb sockets laying around the house and was wondering if I could use 12v dc light bulbs in them? The socket size is the same and I’m assuming that the socket can handle 120v so why not 12v. Here is the link to the light bulbs I’m thinking about buying.
12V LED Bulb E26 7W 630Lm 12 Volt Low Voltage Lights AC/DC 11-16V E27 A19 Edison Lamp(6000K Day White)40-60 Watt Bulbs https://www.amazon.ca/dp/B07MCGH7N4/..._nt.aEbTP3M1GDLeave a comment:
I like this vendor for 12V LED gear.. Generally, the Warm White color, gives me the best feeling. The daylight or 5600K is too blue for indoors, IMHO.
Warm White is lower lumens, but I think better quality. Most 12V does not carry a CRI number
https://www.wiredco.com/LED_Lighting...age_s/1874.htm
Ill look into both of those. As soon as I type in cri for less it’s hard to find anything. Seems like it’s a lot easier to find a high cri for regular bulbs and not 12v.
Most of the newer RV lights are 12v but IMO do not provide a lot of illumination. Actually the best 12v lights I have seen are the kind found in the Harbor Freight solar panel package.Leave a comment:
What does everybody in here do about lighting for a 12v system? I would like to get some led lights but want them to have a high cri?Leave a comment:
Ya I left it on a battery tender until I started using it. Really wish I bought a sealed lead acid instead of this one where I have to add water to it maybe once a month.Leave a comment:
There wouldn't be much current if the batteries are charged.Leave a comment:
I disconnected everything from the cc today and reconnected it the proper way. I don’t think I did any damage but I still connected it the right way for fun.
maybe if I was pushing a lot of amps to it when I connected the solar panel it might of messed it up but it was probably .1 amp or maybe not even.
