Are DIY Solar Panels Worth it?
This is a sticky topic.
  • cyberfast
    • May 2011
    • 33
    #76
    Diy
    I started building my own panels and trust me it is not that fun but can be done. First off the cells are super easy to break. You need a super stead hand for the soldering plus a good soldering gun. You need allot of time. (not a few minute job) Last of after you get the cells together you need to make them water tight and protect them from outdoor elements. My recommendation is if you want to try this buy yourself a small kit first to test it out. don't do the mistake i did and order a huge bulk lot of cells. I'm gonna pay extra and order the built ones.
    Never under estimate the power of hard work. In time something magnificent happens. Dreams are only dreams if you don't push forward. Have a productive day. Tomek.
    • SolarTekkie
      • Jan 2011
      • 24
      #77
      The biggest thing is that they can't be grid connected, and if/when they catch on fire your house is not insured if they aren't UL listed!
      • cyberfast
        • May 2011
        • 33
        #78
        you right about that. i built mine on a trailer for that reason.
        • rhjames
          • Nov 2010
          • 37
          #79
          The simple answer - No. Economically, I found that it's cheaper to buy good panels. This thread and others will give you good information. It's time consuming, and I found it difficult to get the all the air from under the cells when applying the sealant. Mine worked fine, but I could have purchased the same panel at a lower cost, and with a guarantee. I regard solar as a very expensive source of electricity, unless subsidised by tax payers (of which I'm one).
          However, successfully making panels is a fun achievement, but it's best to regard it as an expensive hobby, rather than a cost saving exercise. Whether you build panels yourself, or buy them, it's still very expensive electricity in real terms. It's great if there's no alternative power source.
          • jjohnson
            • Jun 2011
            • 5
            #80
            Catch fire? I've not heard of any DIY panels burning down the house?
              Correctly done DIY won't - any more than commercial panels. The connections can be problematic in any electrical installation if not done correctly.
              Unfortunately not all DIY is well done and by definition there is far less quality control than with commercial equipment.
              Russ
                The problem really kicks into high gear, when you are stringing several panels into a 400v or so, array. Then the DIY insulation goes bad near a corner, or a bad solder joint gets flaky. The high voltage creates an arc, and it's all downhill from there.
                • rhjames
                  • Nov 2010
                  • 37
                  #83
                  400V array - that's quite a setup for DIY!!! There wouldn't be too many of those on a domestic roof. Surely this isn't DC before the inverter? Why would anyone want 400V DC
                    large grid tie inverters need 300-600VDC. Or to move power over longer distance, higher voltage is used
                    • rhjames
                      • Nov 2010
                      • 37
                      #85
                      300 - 600V DC is dangerous stuff. I wouldn't expect to see too many DIY at this scale.
                        ??? Why 'dangerous stuff'?
                        Russ
                        • rhjames
                          • Nov 2010
                          • 37
                          #87
                          DC voltage at this level is deadly - worse than AC. DC current contracts the muscles (eg hand) so they hang on. With AC there's more chance of letting go. However, both are pretty nasty, and anything over 50V either way should be avoided.
                          Being hit with 600V DC would be devastating.
                          • SolarTekkie
                            • Jan 2011
                            • 24
                            #88
                            If you string a few together in series you end up with sometimes 20-50A running through questionable solder joints inside something that's already sometimes 200 degrees F inside due to the sunlight... it's a recipe for disaster.
                              In particular if the soldered connection is DIY - factory done stuff is subject to quality control at least. Like joining aluminum wire to copper - done right it is OK while done wrong it is an invitation to disaster.
                              The main panel in my home is 380 volt 3 phase - I really don't tend to worry about voltage - I do take considerable care though. Anyone who has worked in industrial plants has probably been exposed to a safety culture where there are things you do and things you don't do.
                              I have fired people that didn't think safety rules applied to them. Even if one (or one hundred) gets away with the infraction the next guy may not.
                              Russ
                              • rhjames
                                • Nov 2010
                                • 37
                                #90
                                I think you mean "parallel". Hopefully anyone dealing with these current levels would be experienced at correct wiring. Running undersized cables with doubtful connections in a hot roof space is high risk for fire.
