Small Race Boat Solar Proposal
    between 2 to 4a
    . That's a 100% difference, and not something I can decide on for you.
    The primary $300 Li batteries I pointed to, are military man-pack radio batteries. You can kick them, drop them and they are still going to work. Submerged, most batteries and electronics stop working.
    Figure out your max total watt hours needed for the entire race, and buy that much battery, plus one more, in case "something" happens. For 5 days, solar and it's support gear, is actually pointless, go with the primary batteries. They should be shipable, but customs/duty fees might cost you, but no more than solar gear would.
    And if you don't like free advice from some of the top experience in the field, don't buy any, just make up anything as you go.
    • BlueBell
      • Mar 2018
      • 15
      #32
      Ah, PEng, 40 years, now I understand.
      Good luck with that.
        I do not need luck, semi-retired and quite comfortable. 4 homes, with 1 in Panama. Never snows or freezes where I hang my hat. Try paying me to get detailed answers. Otherwise all I can do is guess what you need. It is not my life on the line.
        If you were paying me I would make you sit down with me face to face and determine exactly how many watt hours you need in a day. That is the very first step end of story. Once you know that, then you can determine if it is even possible. Only advice I can give you now is keep a separate battery for the VHF/UHF and GPS Radios. Sounds like you are going to need it.
        ...---... (SOS)
        • BlueBell
          • Mar 2018
          • 15
          #34
          As luck would have it, I met a retired NASA electrical engineer when I was purchasing my solar gear.
          I bought a Canadian made Rolls AGM, imagine, made in Canada.
          He understood my variable needs as he's a recreational mariner with his own solar array.
          I bought him coffee and he came up with three different scenarios to meet my electrical needs.
          I chose the simplest, which turned out to be of mid expense and now have the battery installed.
          He reviewed the posts here and found some to be myopically obsessive and bombastic.
          Funny how things work out for the best.
          Cheers.
          • Matrix
            • Oct 2017
            • 360
            #35
            Keep us posted both on the system you finally chose and how it works out. Curious to see what set up u went with and how it performs / performed .
            285Wx9 / MNClassic 150 / CSW4024 / TrojanL16H-ACx4
              • 14926
              #36
              Cheers.
              Opinions vary.
