I think a few things have been lost along the way.
1) I have already properly crimped my 2awg battery cables with a crimper I own. However, they are not hydraulic so I have a hard time with thick walled connectors.
2) I thought the recommendation to use 2 hole connectors a good idea because my RV is mobile. 2 hole connectors are all think walled, as far as what I found.
3) So I need to crimp 9 thick walled connectors. Nine.
4) My biggest amperage draw is my fridge which peaks out at 10~ amps with active condenser. Otherwise it sits at a half amp.
5) My daily kW usage is around 8.
6) This is not a 200+ amp setup
7) Nor is it a 100+ amp setup
8) It's unlikely to be even a 50 amp setup (although I have high hopes for my bedroom AC which draws 3.7amps)
With all due respect, insisting on high amperage, high cost solutions to every project, no matter how small, can be counter-productive. Yes, safety is a grave concern, but if you really believe that 50 peak amps traveling through 2awg cable to a crimp shown in that video for maybe 15 peak minutes, is a serious safety concern, I'll say you're being a bit hyperbolic. A bit.
As always, I appreciate this board's thoughts even if not all of them are followed.
