Indiana Senate Bill 309
    • 5203
    #61
    Originally posted by DanKegel
    I'm all for energy efficiency.
    Hypothetical question: if everybody cut their use of electricity by 50%, what would that do to the utilities' balance
    sheets? What would be the best way for them to react to that situation from the consumers' point of view, without going bankrupt?
    I wish that question was more than hypothetical
    Just maybe, the increased number of users will mostly cancel decreased customer consumption. KWH use here has
    been reduced 2/3 from awhile ago, by reducing waste and the best new energy efficient appliances, not affecting
    services. Different now with electric heat replacing propane, BUT its done in a manner to help level peaks.
    Perhaps average customer usage isn't down, but managing it to reduce PEAKS would really help. The PoCo is
    already making attempts to do this. Bruce Roe
      • 2331
      #62
      Originally posted by GRickard
      I see all the time how the environmental groups would like to shut down all of the coal burners, but I don't think they realize that there is not sufficient technology for storage to replace all of the coal with wind and solar. Hydro is a good option, but it is limited as well.
      The strongest factor in the reduction of coal powered plants is the low cost of natural gas. This won't last forever of course, but for the near future coal just can't compete with NG.
        • 15124
        #63
        I work for an engineering firm that does mostly control system upgrades in coal burning power plants. What I am seeing is a lot of plants are being converted to natural gas which gives less BTU's and in turn less megawatts from the unit. Then there is an ever increasing trend to decommissioning the units that were built in the 60's. A lot of these are being supplemented with a row of the small natural gas "peakers" that can be started and shut off quickly to meet demand.
        Greg
        You are correct Greg.
        Shutting down all of the existing fossil fuel generating plants without first installing an equal amount of generating that will be available 24/7 is IMO suicide. Storage technology is still being developed and while it works in some places is still very expensive.
        • GRickard
          • Dec 2016
          • 122
          #64
          As far as the small natural gas combustion units, the plant people tell me that it's more cost effective to run the large coal unit due to the increased maintenance cost of the engines. They have to be shut down after so many hours to change oil just like any other engine.
            • 2331
            #65
            Right. People aren't replacing large coal units with small natural gas peakers; generally they are replacing the large coal units with large combined-cycle natural gas units. They're cleaner, cheaper, more efficient and are (often) easier to throttle. Large, fast startup/load following combined cycle plants are becoming more common; this reduces the need for those small peakers.
              • 14927
              #66
              Peakers are by nature, purpose and design, smaller than sources of baseline loads. Peakers can fire up quicker. That added and needed flexibility comes at a cost however. That cost is usually higher maintenance for the peaker and a bit lower cycle efficiency, both leading to increased operating costs, and, as a no brainer, higher differential rates to the extent the POCOs can talk the PUCs into being allowed to charge higher differential rates for peaker power.
              • DanKegel
                • 2093
                #67
                Variable pricing like that makes a lot of economic sense.
                blog.aee.net/time-varying-rates-an-idea-whose-time-has-come lists a few places that are starting to do something similar.
                • DanKegel
                  • 2093
                  #68
                  Several utilities are installing or proposing electric car chargers to do exactly that. Kansas City's effort was on the radio yesterday: npr.org/sections/alltechconsidered/2017/02/14/514517425/in-americas-heartland-a-power-company-leads-charge-for-electric-cars
                    • 15124
                    #69
                    Being able to shift the load to the daytime will usually help any POCO that sees a peak in the evening. Although with smart controllers those EV's could be charged late at night when the peak demand has dropped.
                    IMO having more EV chargers out in the work place would be a major help for the EV manufacturer to sell more cars as opposed to the POCO to needing to reduce peak demand.
                      • 14927
                      #70
                      Dan: Of course it does - a real no brainer there - but don't take my stuff out of context and meaning.
                      • DanKegel
                        • 2093
                        #71
                        It's a virtuous cycle. The utilities are seeding the market with chargers ahead of demand.
                        They're betting this will drive EVs sales, and as people see their neighbor saving time and money with their EV, yet more EV sales and yet more even demand... lessening the need for peakers and other POCO investment. We'll see whether it works.
                        (How many EVs on 6kW chargers would it take to make a difference? Well, KCP&L has a bunch of 77MW peaker plants... 77 MW of flexible ev charging load might let them get away with one fewer. That's about 12,000 cars on smart chargers. There were 1200 EVs in KC last year, so it may be a while before they hit that.)
                          • 14927
                          #72
                          And [unlikely things will happen] soon as well. Did you read that in some treehugger rag ? Or is it more of your homegrown wishful and ignorant nonsense ? Any logic behind what you're writing ? Sounds more like your usual pie in the sky, ill informed nonsense to me.
                          Last edited by inetdog; 02-15-2017, 03:01 PM. Reason: Changing a gratuitous insult to a simple insult
                          • DanKegel
                            • 2093
                            #73
                            I admit, it's hard to argue with clear, logical, well-reasoned posts like that. You win!
                              • 14927
                              #74
                              And a whole lot easier than looking for common sense and anything useful in your stuff.
                              Good. Well, that's a start. Now learn how to think before you write. Then think some more about how what your write may affect others. You're not the only one playing in this sandbox.
                                • 15124
                                #75
                                More than likely a reason for the POCO's to "seed" the market with charging stations is really an attempt to increase revenue and take it away from the Oil companies that sell gas.
                                I still hold firm to my statement that without a charging network out at the workplace the sale of short distance EV's will stay flat due to people not wanting to have their car stop working on the way home.
                                So install more charging stations or develop larger batteries for longer driving distances. Both are motivation for the EV business and not really something for the POCO to invest in.
