Tesla Wants to Build a Battery for Your House
SCE has credited me almost that much... in three months. This is after solar has provided for 99% of my use.
Go Solar!!Comment
There's no empirical data that I could find anywhere on the site to support the contention that $3,000 was not the cost I'd pay if I reserved a 7KWh battery today. Do you have this data? Agree that installation costs are probably extra but I was doing "rough numbers". I'm not saying this is an incentive to buy one either: the guarantee is only for 10 years I believe.4KW system featuring Suniva OPT265/Enphase M215Comment
Agree on that. Here's output from my 4KW system.
However, right now, grid-tie is good, but demand charges can change this. POCOs need to do demand charges and I agree with them, however, they can do it cheaper once they have cheaper energy storage systems. Local placement of large storage systems not only supports renewables, but also reduces load on transmission lines.4KW system featuring Suniva OPT265/Enphase M215Comment
http://www.teslamotors.com/presskit/teslaenergyThere's no empirical data that I could find anywhere on the site to support the contention that $3,000 was not the cost I'd pay if I reserved a 7KWh battery today. Do you have this data? Agree that installation costs are probably extra but I was doing "rough numbers". I'm not saying this is an incentive to buy one either: the guarantee is only for 10 years I believe.
"Tesla’s selling price to installers is $3500 for 10kWh and $3000 for 7kWh. (Price excludes inverter and installation.) Deliveries begin in late Summer."
"SolarCity will install Tesla's batteries for $5,000 (which is on top of the $3,500 price tag for the battery itself)."Comment
You can reserve one and get your price.
The reservation process should tell you the distributors in your area, if any. This battery will likely only work with inverters designed specifically to the unit. The Powerwall does not appear to be designed for end user installation.Comment
Based on that data, I concur that it doesn't sound like any kind of deal. Even @ 3K installed, optimal payback is 2 years after the guarantee expires.4KW system featuring Suniva OPT265/Enphase M215Comment
And the math gets worse when you assume system efficiency (approx 90%) and battery degradation over time. Then, probably double the price for additional equipment, materials and installation = throwing money away. Hopefully, the early adopters don't mind, and we will have an affordable option 5 or 10 years down the road.24xLG300N+SE7600 [url]http://tiny.cc/n7ucvx[/url]Comment
No that is where you start. Next you look up thee Patent and UL applications.
Tesla is using the same batteries they are using in the S model car. If you know anything about batteries, the most basics of physical properties, is that batteries physical size in volume and weight are directly proportional to the energy capacity contained within them. A 10 Kwh battery is going to be 42% larger and heavier than a 7 Kwh battery. It is simple 5th grade math.MSEE, PEComment
Then why did you say this ?? Maybe your lost or having a bad day remembering anything. looks like the math is your problem. Guessing again.No that is where you start. Next you look up thee Patent and UL applications.
Speculative (likely an educated guess however given your background) but irrelevant since my statement was a best possible rough guess that still won't pan out. Its not a good deal assuming optimum pricing and zero degradation over time.4KW system featuring Suniva OPT265/Enphase M215Comment
Just where is the problem? No guesses, just physical facts. The battery is 400 volts @ 24 AH aka 10 Kwh in both models. 7 Kwh is restricted to 70% DOD.MSEE, PEComment
