Nice! I like both of those ideas! I have an add-on actuator on the ball valve for the water main coming into the house that works really well, and I thought of using the same setup for exactly what you described. Guess I'll first see how well the check valve functions after installing the strainer.
Adding monitoring to existing solar thermal system
Nice! I like both of those ideas! I have an add-on actuator on the ball valve for the water main coming into the house that works really well, and I thought of using the same setup for exactly what you described. Guess I'll first see how well the check valve functions after installing the strainer.Comment
I have used bag filters in the past to clean up piping contamination with excellent results, never had much luck with Y strainers for cleanup just for stopping the large chunks that could lodge in the impeller of a pump. The replacement bags come in different micron capable sizes to remove even the finest particulate and are washable for reuse.Comment
East Coast Filter, Inc. strives to make your Filtration Needs our Highest Priority and it is our Mission to help our Clients improve Efficiency and Business Profitability Today and Tomorrow.
You will need the steel version, they are expensive. You could make one easily enough with some scrap 4" D x 16" long steel pipe after you purchase a filter for sizing. Water flows into the bag and out the sides and bottom.Comment
https://www.eastcoastfilter.com/
