Good deal. Thx!
Adding monitoring to existing solar thermal system
East Coast Filter, Inc. strives to make your Filtration Needs our Highest Priority and it is our Mission to help our Clients improve Efficiency and Business Profitability Today and Tomorrow.
You will need the steel version, they are expensive. You could make one easily enough with some scrap 4" D x 16" long steel pipe after you purchase a filter for sizing. Water flows into the bag and out the sides and bottom.Leave a comment:
Outside of any industrial applications in use before I retired that are still in use, I'm ignorant of current products. But, I'd guess a regular filter would get most/all harmful particulates out of a PV system. I'd be more concerned about the chemistry of any old/aged heat transfer fluid.Leave a comment:
If I needed to strain I'd use both to to keep shavings/filings away from the fine mesh and perhaps tearing/cutting/impairing the mesh efficacy.I have used bag filters in the past to clean up piping contamination with excellent results, never had much luck with Y strainers for cleanup just for stopping the large chunks that could lodge in the impeller of a pump. The replacement bags come in different micron capable sizes to remove even the finest particulate and are washable for reuse.Leave a comment:
Depending on how thorough the cleaning was, etc. and because things like check valves tend to be catch-alls for debris in a system, expect to be either cleaning a check value quite often of at least checking it - which is pretty much the same thing.
Nice! I like both of those ideas! I have an add-on actuator on the ball valve for the water main coming into the house that works really well, and I thought of using the same setup for exactly what you described. Guess I'll first see how well the check valve functions after installing the strainer.Leave a comment:
At one time I settled on a bypass to the plumbing similar to what's often done in industrial applications around the check valve so as to be able to remove/service the valve without shutting the system down.
My current setup uses a motorized ball valve with power passing through the differential controller; pump on = valve open. pump off = valve closed. Fit for purpose.
I think I understand. Check valves are, for the most part, junk stops in a system and need regular cleaning, particularly after a system flush as you've done.
My apologies, that pic probably requires further explanation to make sense. The reason you see oscillation in the early AM, but not in the late PM is because I manually closed the ball valve (integrated into the check valve in this case) after the sun went down, in order to stop the thermosiphon. I've actually had this check valve taken apart a couple times within the last few weeks where I found and cleaned out debris that was keeping it from closing. The trouble is that I'm still fighting with those gunked up collectors that you guys were helping me with in the other thread. I did finally get the 3rd collector flow rate up to the same as the other two (and inserted back into the loop now) by cycling vinegar through it by itself with a drill pump. Not knowing any better, I had in my mind that the "gunk" clogging the collector was some sort of sludge. Turns out the material that was clogging it up reminds me more of small pieces of slate. It's rock hard, yet brittle. Anyway, those pieces keep flaking off and making their way to the check valve where they get stuck (this is even after flushing the system for what probably totals to hours altogether). I've ordered a wye strainer that I plan to install before the check valve to help me deal with the issue. Anyway, sorry for the detour, but thought you might be interested.
I've had several different check valves in my systems and none were worth much.
My current setup uses a motorized ball valve with power passing through the differential controller; pump on = valve open. pump off = valve closed. Fit for purpose.Leave a comment:
My apologies, that pic probably requires further explanation to make sense. The reason you see oscillation in the early AM, but not in the late PM is because I manually closed the ball valve (integrated into the check valve in this case) after the sun went down, in order to stop the thermosiphon. I've actually had this check valve taken apart a couple times within the last few weeks where I found and cleaned out debris that was keeping it from closing. The trouble is that I'm still fighting with those gunked up collectors that you guys were helping me with in the other thread. I did finally get the 3rd collector flow rate up to the same as the other two (and inserted back into the loop now) by cycling vinegar through it by itself with a drill pump. Not knowing any better, I had in my mind that the "gunk" clogging the collector was some sort of sludge. Turns out the material that was clogging it up reminds me more of small pieces of slate. It's rock hard, yet brittle. Anyway, those pieces keep flaking off and making their way to the check valve where they get stuck (this is even after flushing the system for what probably totals to hours altogether). I've ordered a wye strainer that I plan to install before the check valve to help me deal with the issue. Anyway, sorry for the detour, but thought you might be interested.Leave a comment:
I don't think the oscillating collector temps are f(a stuck check valve) as much as a differential controller that's got a problem.Leave a comment:
A few thoughts. First, I can't say enough good about the Flume water monitor. Got mine for less than $100 used on eBay. It's super simple, just straps to the side of a water meter (guessing it has a hall effect sensor of sorts built in). It is accurate, and a detailed history of usage is accessible from their website and/or mobile app. So the way it's advertised, it would be a solution for monitoring "cold usage of the home" by strapping to the city's meter, but I'd guess that it will work with any meter detectible by a hall effect sensor (like possibly the meters that LucMan linked to). On Flume's website, they have a list of the meters that are compatible, though that list is probably focused on higher end meters that a municipality would install.
Second thought is that you could take the output wires of a hall sensor type meter and count the pulses with a micro-controller (converting to flow rate within your code). I used to use my particle photon for this exact task and it worked great. As I'm sure you are aware, there are a number of ways that you could store and visualize the data from there. Just for kicks, here is a pic of how I'm graphing temps now after your suggestion. Along with the temps, I'm bringing my PV system and flume data into the same InfluxDB database, so it can all be graphed together. I'm a sucker for charts anyway, but this has actually been very helpful in detecting a clogged check valve, as can be seen by the oscillating collector temps in the pic.
Third thought is that if you are like me and just trying to track flow through your heat exchanger loop for the purpose of calculating kWh, and if your pump is a fixed speed, and if you know the flow associated with that speed (perhaps just by the eyeball type meter that J.P.M. mentioned), then all you need to do at that point would be to track the "on" time of the pump, which could again be done with a microcontroller (and and relay or current sensor or something). Incidentally, this thread looks like it might have the formulas for this calculation, though I don't yet understand it fully. https://sustainability.stackexchange...t-water-system.Leave a comment:
Go here for monitoring controls if you feel you can't live without it http://www.solar.imcinstruments.com/index.html.
Graphical software available.
These are excellent quality controls, from basic differential - too all the bells and whistles.Leave a comment:
For solar thermal systems I've had good good luck with Pentair. An outfit called "Blue-White" also appears to make a suitable product. Just get a rating of +240 F. and keep the system pressure below the rotameter rated pressure and avoid buying anything with non metallic threads.
If by counting you mean how is the flowrate measured, that's done via the "GEB" system. That is: "Good Eye Ball".
The Rotameter "counting" is done by reading the level of the float inside the rotameter against a scale on the side to the device, which side is transparent so as to allow the float visible.
But I think we're not talking/thinking the same types of monitoring. I like no more complicated than necessary for the task at hand. I'm using 10 k ohm sensors and multimeters to read the output and convert a resistance to a temperature.
Rotameters are a type of flow meter that's of the direct reading type. There are no alarm conditions on my solar thermal systems.
Using simple methods,I know as much or more about my systems' capabilities than most anyone may need to know and probably a good deal more. And - a bonus - , with simplicity comes added reliability. Leaks, breaks and system upsets are minimized with good design and knowledge of what's required to achieve the desired level of safety and reliability. Lots of bells/whistles, the reasons for which are poorly or not understood are a poor substitute for good design.
The sensors are ~ $10 - $20 ea. and the rotometers run between $80 - $150 depending on flowrate range and mostly vendor. I've designed industrial flow control and monitoring systems for refineries and for power plants but a residential or similar size solar thermal system doesn't need that level of complexity. The only alarm necessary on a well designed solar thermal system (and it's not an alarm as such) is to turn on the pump in a direct system to prevent a freeze burst. There are other freeze protection methods, but they are of dubious value. I suppose I could rig a battery powered buzzer if the power failed and a freeze event was likely to occur.Leave a comment:
