I paid a licensed solar installer to pull the permit, deal with the utility, and install the system. If I were doing it again I would do it myself and hire an electrician to do the final hookup. I used microinverters but with a big inverter it would make sense to have the electrician "install" the inverter to protect your warranty. In 7 years I haven't had a hiccup from any of 22 Enphase microinverters or Solarworld panels. I think your risk of substantial loss due to warranty-covered failure is low with microinverters and panels because each individual unit is fairly inexpensive vs. a big string inverter.
Most Popular Topics
DIY installs and warranty? Only valid if installed by a licensed electrician?
I have had had to replace a Solaredge inverter and an Enphase Microinverter. Both were self installed and there was no issue. In both cases they did not even ask if a licensed contractor did the install. Perhaps electronics can be diagnosed remotely so that may be all those manufacturers need.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
My AC to DC converter I just bought has the “must be installed by licensed electrician on it” and went bad. THe company is processing the warranty now.
I bet this is in a lot of electronic components which a company could use to void the warranty if they get something was fishy with the return, or just void any warranty if they wanted to.Comment
