I doubt the guy 5 miles away who also has a PV system is going to be impacted by you or is going to impact you.
Maybe if it were a utility scale system (ie. 100kW+) it'd have enough impact on the grid, that you would notice it.
What it sounds like is you're still at the edge of being too high of voltage that it's causing your system to disconnect.
What did the POCO say was the voltage range they deliver to your house?
Is 252V within *their* spec?
What did the serviceman find when he came to your house? What was the voltage at that time? Is the POCO going to do anything / make any changes? If so, what?
I'd consider getting a TED5000 or similar system hooking it up and having detailed data on just what the voltages actually are. (If you can get the data from your SMA inverter, great - if not, buy or rent something that can get the data and show you what the voltages are throughout the day.)
After you have answers from the POCO, you'll have an idea on what to do moving forward.
