Ok so I've had my system up and running for a few days. So I just been crossing some t's and dotting some i's. Getting the inverters connected to the internet and getting monitoring going ect.
I'll cut to the chase my one inverter seemed to be performing like 25% of the other one. So yes I have 2x sma sb 7.7 us 40 inverters. Each inverter has same number of strings same # of panels. All panels azimuth is the same angle everything identical.
I had hoped a software update would fix it, no dice. What is happening is when the sun is in the peak position.. the one inverter is basically pumping out the maximum. 7.7 kw the other errors out and sits idle saying it's an issue with the grid, grid fault, overvoltage ect.
So today I came home early from work. Turned the inverter that seems to be performing correctly off to see what the other one did. Amazingly it started pushing out the max 7.7kw almost immediately. That being said it kinda rules out the inverter being bad or any issues associated with it being connected correctly ect.
That narrows it down to having something to do with my grid. Obviously the electrical grid (as it relates to the poco) is fine if the system has no issues keeping 1 inverter happy. The only thing at this point that I can really say maybe the issue is that I have both inverter connected to a subpanel and theres no other loads in the panel (yet). The first thing I'm going to try is to move one of the inverter breakers to the main panel and see if the fact that theres constant loads in there will lower the voltage some and allow it to operate as intended. If for some reason that doesn't work then I'm pretty much at a loss. I know I've seen other setups with more than one inverter and the manual even shows different (mounting) scenarios with more than one so I know this is supported. Anyone have any experience dealing with this type of problem ? Any input would be appreciated.
