I highly doubt most folks doing DIY off grid solar are getting an electrical inspection. Does an installation with only 48 volt and below even require a permit?
Most Popular Topics
What would residential solar look like without net metering?
Since I'm off-grid, wife will not allow outages and I have to be at least as reliable as local grid (4 blackouts/yr) To get decent reliabilyt, corners cannot be cut, batteries have to be ample capacity, PV and Generators have to be properly sized. Sure, going with a couple marine deep cycle batteries would be cheaper, but I'd have outages in the winterLast edited by Mike90250; 03-19-2018, 11:13 AM.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Possibly though my point was on the production and usability. Since off grid produces less, you generally have to install a bigger system to get similar power as well as use a lot less. Something many of us know but a few in this thread seem to be missing.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
If it is on an occupied home it would need permit and inspection in most states. We have installed several. If it is ground mount it likely would also need permit for the structure.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
MSEE, PEComment
