Here is the explanation. It was it makes the Solar Panel worth in Mass:
Having a hard time deciding between LG and sunpower proposals
1) I use around 950 KWh per month. Have 2 small kids, Electric Washer and Dryer. My wife stay home most of the time.
2) In PVWatts it is around 12280 KWh. So I am a little over (maybe for a Model 3 in the future). But also some winters around here are brutal and may offset this value some. So I believe I am on the correct value. I have been living here for almost a year, so I have some but not extensive energy consumption history.
Thanks
I was asking because, not seeing any mention of your sizing logic or load, and often, people not understanding how to size a system to either meet a need, or that a 100 % off set may not be the most cost effective long term way to go, wondered how you got to the size you did. No more than that.Comment
You're welcome.
Completely understand. But I did all possible calculations and scenarios (I am an Engineer, so I do not buy anything before doing extensive calculations and research) and it looks a good investment. Also I could not see a reason for not aim for 100% (is there any scenario where 100% is not the most beneficial)? Here at MASS as more as you produce, more SRECs you recover back, so proportional you only pay around 18-22% of the initial price asked and it normally pays off in 3 to 4 years if you buy a reasonable price system.Comment
Just keep an eye on the SREC credit value changing -- reading at this site it looks like there is a surplus of "suppliers" and unless your credit rate per SREC unit is locked in. it looks like it could easily slip lower.
I suspect, you are all over this based on your other replies.8.6 kWp roof (SE 7600 and 28 panels)Comment
