Anyyyhowww, I dont want to side-track his post. Back to chuckgm3
Please help me decide on which way to go. (enPhase vs SolarEdge vs LG)
At the end of the day when I am producing 0kWh, the # that is directly on the inverter display, matches perfectly with their web portal. It's just that since PVO can only grab the data from SE API every 15 minutes (to avoid maxing my # of connections per day) it is only getting the production at that moment, not the total produced between my polling intervals (as I understand it) so those metrics are just a bit off.
Somehow the Solaredge monitoring alway shows little higher on output vs. other made inverters. I'm not sure if solaredge really that "good" or not. DC vs AV @ 0.93 wow. Hoping someone has revenus graded meter to confirm the realy output.For everyone's information other than chuckgm3 as I know him personally (I told him to post here) and we've discussed my solar setup at length...
I have the LG305N1C-B3 DC's with the SE P300 Power Optimizers and the SE6000US string inverter. I have the inverter inside my garage, out of the sun. So far it barely gets warm.
This is yesterday for me at my peak, it seems about 280-285W per panel right now. So with 250W max AC out of those Enphase, I can't imagine you won't be clipping at the micro inverter 250W max AC output.
:EDIT: and in *my* mind, I'd be deciding between the SE setup and the LG micro inverters with what I know now. I dont think I'd do the Enphase with that clipping issue, but I wasnt sure, so I said lets get feedback here. If the clipping was a moot point, I'd consider them.
And of course here was my similar thread last year when I went through this
http://www.solarpaneltalk.com/showth...s-got-some-Q-s
[ATTACH=CONFIG]6680[/ATTACH]Leave a comment:
Thanks for the info on that. Yeah PVO may show me at like 40.xkWh produced, but yet my inverter or the SE site you see shows 42.x. My friend with the Enphase says that he gets nearly perfect data to PVO.@AaronG
Your PVOutput data is presenting a much more accurate picture of your production than the SolarEdge energy or panel data. I've recently installed a revenue grade meter, and the agreement between it and other calculations I've performed based on back calculations from *known* household consumption, I am confident stating that depending on the report you are looking at, SE is overreporting by as much as 4%.
Looking at your PVO data from yesterday, you can see that if you had Enphase 250's, your output would have been capped at 5250 W. You exceeded that from about 1:00 pm to 3:30 pm. The total energy "clipped" would have been about 0.57 kWh. As we get further into summer, that amount clipped is likely to drop (due primarily to temp increase and less optimum sun angle).
In other words, the amount of energy lost due to clipping in an Enphase 250 + LG305 system is not likely to add up to very much. I would suggest that the choice between them is better made by preferences in cost, inverter tech, warranty, or installer preference than by any difference in total system output.
Also, for PVOutput donators, a revision to the SolarEdge uploader has been made that allows data with 5 min resolution, instead of 15 min. All you have to do is update the status interval to 5 min... leave the polling interval at 15 min to avoid running into SolarEdge's API call limit. Unfortunately, the way SolarEdge calculates their averages means that synchonizing the generation data with the net consumption data from Wattvision (or the Eagle device directly) is kind of a lost cause, and especially on cloudy days, you should expect to see lots of weird spikes and perhaps bad daily totals for the calculated consumption.
Yeah if the clipping only results in a smaller amount of lost kW, then maybe if he is paying thousands more for it, it doesnt make sense. Or if the warranty is way less then it doesnt make sense. I did get 20yr warranty on my SE stuff, but not 25 like he may get on his Enphase stuff. My installer quoted me the same price for a SE inverter with SE Power Opt. vs the LG Micro Inverters. Enphase was never on the table.Leave a comment:
@AaronG
Also, for PVOutput donators, a revision to the SolarEdge uploader has been made that allows data with 5 min resolution, instead of 15 min. All you have to do is update the status interval to 5 min... leave the polling interval at 15 min to avoid running into SolarEdge's API call limit. Unfortunately, the way SolarEdge calculates their averages means that synchonizing the generation data with the net consumption data from Wattvision (or the Eagle device directly) is kind of a lost cause, and especially on cloudy days, you should expect to see lots of weird spikes and perhaps bad daily totals for the calculated consumption.Leave a comment:
solar.jpgLeave a comment:
Your numbers seem off. I calculate $4.00/watt pre-tax credit. May not be too bad since panel upgrade is included. That array with a 300 degree azimuth suffers a ~25% loss in annual production compared to a zero degree azimuth. You are apt to see some clipping on occasion using the Enphase 250 watt micros. Whether it would be significant $$ wise, it's hard to say. How hot does it get where you are? If you're inland and summer temps are above 100F, consider that baking all the power inverter electronics on your roof might be worrisome. SE puts much of them in the wall mounted inverter which is better IMHO.Here are the details I'm looking at. I do have some shading from a neighboring tree. I thought I'd prefer micro inverters to the SolarEdge but I'm not entirely sure.
One thing that's got me a bit confused. My sales rep insists that the EnPhase M250 micro inverters are a good match for the LG 305w panels. However, as I understand it, the M250's would be a bottleneck at 250w each, not allowing my 305w panels to produce to their full potential. I know they won't hit 305, but I've seen them produce 280+ on a good day. Am I missing something here?
7.6kw system
9,349kWh /year production (estimated)
$30,424 before rebate.
$3.25/kWh
This includes:
25x LG305w Panels
25x enPhase M250 microinverters
200amp Main panel upgrade
Installation, permits, roofing repairs, etc. etc.
25 year warranty on everything
My roof it a bit oddly shaped so the design has 3 arrays
Array 1: 15 Panels, 30deg tilt, 210deg azimuth
Array 2: 7 panels, 30deg tilt, 300deg azimuth
Array 3: 3 panels, 30deg title, 210deg azimuth
If I go with SolarEdge optimizers and inverter, the price only drops by about $500. If I want them to use LG305A1C-B3 with built-in LG micro inverters which presumably would not have the same 250w bottleneck as the enPhase inverters, I'm looking at an additional $2000.
This is in SoCal, I'm on Edison's TOU-B plan and I have an electric car.
Any input is appreciated. Thanks in advance.Leave a comment:
I'll have wine instead.
I used Solaredge for my house
How I see it compare to enphase:
* Similar per-panel monitoring
* Similar ease of expansion (add panel and racking, hook up the optimizer into existing string of optimizers)
Downsides:
* Shorter warranty
* "big, clunky inverter box strapped to the side of my home" (but that doesn't really bother me)
Upsides:
* Cost/price
* Cost/price
* Did I mention cost/price?
* maybe better effiiciency with inverter in shade on side of house, rather than on roofLeave a comment:
Its almost like asking what your favorite beer is.... much is personal preference.
I like my Enphase inverters, I like the performance and the monitoring program, and I like the 25 warranty.
I like the warranty my installer gave ( to basically step in at any point in the 25 years where Enphase cannot / will not honor their warranty), and I like they are cheap.
I like they are out of sight, out of mind. No big , clunky inverter box strapped to the side of my home, with conduit running everywhere.
I even bought 2 extra ones on Amazon, for $139 each.... just in case.
If I dont think I need them, I can always add 2 panels to my system. With Enphase, expansion is effortless.
I think I'm set for the next 20 years..... Easy-PeasyLeave a comment:
There were quite a few threads about enphase vs solaredge with LG300/305. Here's a more recent one http://www.solarpaneltalk.com/showth...-kW-San-Marcos FWIW. the investment community seems to like solaredge much more. SEDG is now 3x the capitalization of ENPH which has been in the business a lot longer.Leave a comment:
7.6kw system
$3.25/kWh
This includes:
25x LG305w Panels
