Most Popular Topics
North County San Diego estimates for new install
One other small, anecdotal item: Alisobob and I have different systems. His is LG at ~ $3.50/Watt (as I recall). Mine is Sunpower for a lot of reasons that are not germane to this thread. I paid $4.50/Watt. My system's about a year older or so than Bob's.
The interesting part to all this is that, as best as I can call it, our outputs are about the same in terms of kWh/year or per month produced per installed nameplate kW. It's not exact, but what I'd call spookily close, particularly on uniformly clear So. CA days. Same for a lot of PVoutput stuff in San Diego, for similar orientations.Comment
Bottom line for me: I'd still go for the LG, based on 2 things: The idea that a super low S.P. price, while tempting, may well also serve as an excuse by the installer to cut a few corners they might not otherwise be cut., It's more than about low buck - its about most bang for the buck. And second, I'm pretty sure I can find get an LG system for about $3.50/Watt around here and preserve quality.Comment
Originally posted by sunfusionsolarsthe installation of solar panels entails various processes. In some instances, it can depend on the kind of roofing you have. A solar power engineer will have to examine your roofing to check if it is an
ideal location for installation and to ascertain the best installation procedure. Upon examination, the technician will likewise determine the right way to position the solar panels. This is vital for
achieving optimum efficiency when generating electricity.
Solar panel installation technicians are effective in installing panels on different kinds of roof. For instance, if your type of roofing is tin they will have to install a rail using big gauge screws
for optimum durability. Also, they will fix a tin mounting foot to help it become more stable. After that they will then position the feet of the solar panels over the rail.
You can get the benefits associated with using solar energy if you pick the best types of panels and have them mounted by an expert. Contact BS.com for reliable installers in order
to begin receiving the benefits of solar power.Comment
Thanks for the advice so far. PM request of contractor info is for anyone that would be willing to share. I can't PM yet.
I got additional quotes based on the belief that Sunpower panels would not be the most cost effective for us.
Here's what I've been given: (would be happy to repost of new thread if more appropriate than staying on this one)
Contractor 1:
20 LG 280S1C -B3 panels
Solar Edge SE5000A-US inverter
cost: $21,784
$3.89/watt
They use a quickmount system and Univac racking. Their claim is that the Tile-trac system of contractor 2 is not double flashed like theirs.
Contractor 1 feels we have shading issues based on a google map image that he is using from December. He did not use any other data, didn't look at or get on roof when presenting his quote. We were surprised at the shading assertion. Hadn't felt like it was an issue, but didn't dispute because of the google image.
Contractor 1 rep said that poly crystalline panels are inferior - that they are using the scrap/ leftover parts from mono crystalline panels. He said that Kyocera panels (quoted by contractor 2) are favored in commercial installations where the customer is primarily cost driven.
Contractor 1 initially quoted LG's 300A1C's panels (as well as Sunpower). I asked him to quote 280s since I couldn't find reviews of the newer panels and their cost was pretty high as well.
Contractor 2
22 Kyocera KD260GX-LFB2 panels
1 SMA America: SB-5000TL-US-22 (240V) inverter
Cost: $22,169
$3.88/watt
Contractor 2 Saw the google map image but says our shading issues are minimal (only coming into play at all in Dec and Jan). He went up on the roof with some sort of opti eye device and then showed us a computer image of what our shading issues would be year round (down to the time of day). His data showed that only during Dec and Jan would be when we'd have any shading and that would only be before 8 am and between 2-4 pm.
Contractor 2 disputes that his installation system doesn't double flash. He says double flashing is required by code/ permitting. They prefer not to affect the integrity of the s tiles as much as the installation method of contractor 1.
Contractor 2 feels poly crystalline panels are maybe less efficient, but still fine to use. Felt Kyocera was a quality panel.
Contractor 2 was much more of a fan of string inverters than contractor 1 (possibly because of #1's concern of shade).
Contractor 2 talked a lot about their Nabcep certification. Contractor 1 talked about their parent company's 75 year history, made no mention of Nabcep. Contractor 2 has no well established parent co., but has been doing solar longer than contractor 1. (both have over a 5 year history)
Contractor 2 didn't initially give me a quote using Sunpower panels. He did when asked, and they were within a few hundred dollars of contractor 1 based on same system.
Contractor 2 would take 1 month or maybe 2 longer to be able to start the job due to work load. Expects completion would be by August 1.
So the cost and production of both bids seem comparable. My main concern is the validity of their claims (installation style, poly vs. mono, shading issues).
Any advice/thoughts would be greatly appreciated. Thanks.Comment
From my own experience, all the 10+ quotes that I had gotten from solar-only installers were higher (and in some cases significantly higher) than the quotes that I got from C-10 electrical contractors who install solar. FWIW.Comment
Are you sharing quoted information with the vendors ? Those prices are so close it's a good example of what happens when one vendor knows what the other is quoting.
FWIW: those $ #'s seem high for LG 280's unless something is in there besides just the system.Comment
BTW the LG280W at $3.89/W still sounds expensive.16xLG300N1C+SE6000[url]http://tiny.cc/ojmxyx[/url]Comment
Thanks everyone for all the feedback. Disappointing to hear that the prices are still out of line. Are they so out of the ballpark that they shouldn't be entertained at all? We've been told that the size of the job may be making our $/watt seem higher than others, but others here seem to be getting quotes on similarly sized projects.
We did tell the vendors what panels the other co was quoting, but not their prices. Even that may have been a mistake in retrospect.
Does anyone have any knowledge regarding the accuracy of the optic eye device reading to predict shade and if we shouldn't be concerned with the limited presence of shade as predicted? It would affect 2 of the panels during the winter hours referenced before (assuming reliable predictions).
Any thoughts on the two different install methods?
Some of theses non-price components of their approaches seem to speak to their overall knowledge and trustworthiness.
Sounds like we should get at least a couple more bids so PMs with recommendations would be great. These two companies are the only ones that I've been able to get personal referrals for so far.
Thanks again for any/all feedback.Comment
So I have gone around and around on this trying to work out using our Heloc but its not possible so I am left with the following options (I would appreciate input):
SD Metro 2.99 rate
Contract Price - $24633
Bank upfront fee - $3867
Rate - 2.99
Term - 12 years
30% credit - $8550
Sunpower F&F Credit - $3000
Re-amortized loan balance to pay off - $16950
Total cost over 8 years - 19079
I can pay this off in 8 years at $200 a month and only incur 2100 in interest costs over the life of the term. I cannot deduct the interest as its a secured loan against the equipment but should I need to move, I could pay it off in the sale of the home or move it with me.
HERO program
Bank upfront fee - $1324
Annual fees - $35
Rate - 7.69
Term - 10 years
30% credit - $7787
Re-amortized loan balance to pay off - $15170
Total cost over 8.5 years - $21007
I can pay the same 200 a month over 8.5 years but incur 5500 in interest over the term. I can deduct the interest but would need to manually pull it out from the tax bill annually. No payments would be due monthly but we would need to be ontop of the money being put away because we dont have an impound account for taxes. This loan takes 1st priority against the home and can cause issues if we were ever to sell but we are never moving which is the reason I am going strongly on this.
I could use the deduction but not sure its worth it for the hassel involved. I looked at point loma credit but their rates were higher than the HERO program.Comment
What was the best non Sunpower proposal you got? The costs you are looking at are higher than I would have been willing to pay.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
