SMA String VS Solar Edge with Power Optimizers
Some of those points are factual, others, less so. Sullivan lost all credibility with me when they started marketing BS about net metering ending this summer, so I'm not inclined to believe them on the points that can not be verified in the public record.
Edit: I'm not sure I would use failures in what is described as a beta test as a knock against any particular system. That is what beta testing is for, after all.
Double edit: The transformerless inverters made by SMA have also been on the market only a few years. NEC didn't really allow them before that. Claiming that SMA the company is better just because they have been around longer is strikes me as the same kind of fallacy they are trying to accuse others of. There is no way to know who will be around in the future, any company can disappear at any time. SolarEdge is likely to go public this year, so the point about private ownership doesn't carry much weight any more either.Comment
The arguments made in the email make some sense. I would take issue with #3, though. It is not unusual for a new and growing private company to seek additional funding for growth. If they get that funding, I'd say it's a positive not a negative. In fact, there's a good chance that Solar Edge will go public in an IPO this year. That article also states that the company was profitable for the last six month of 2014. I find it interesting that Solar Edge seems to be catching up quickly to Enphase in number of units shipped. Item #5 is careful not to state which optimizers they found problematic - it's unclear whether they tested what Solar Edge is currently selling.
That installer appears to be fairly conservative - going with the tried and true - and there's nothing wrong with that. SMA has an enviable and lengthy track record which is a real plus in this business.Comment
Thanks!!Comment
I hear you. . . and we are probably paying more for the name. But the overage in the great scheme of the total price is not monumental. Our goal was not to just get the lowest price, but to also feel comfortable with what we are purchasing. . .we'll be in this house for a long time. As you know, figuring this stuff out is a bear. . .so much information, misinformation and ambiguity.
Thanks!!Comment
Discover real-time SolarEdge Technologies, Inc. Common Stock (SEDG) stock prices, quotes, historical data, news, and Insights for informed trading and investment decisions. Stay ahead with Nasdaq.
Discover real-time Enphase Energy, Inc. Common Stock (ENPH) stock prices, quotes, historical data, news, and Insights for informed trading and investment decisions. Stay ahead with Nasdaq.
I believe SolarEdge just listed on 03/26/15 and now seems their market cap is even larger than Enphase or SMA
http://www.google.com/finance?cid=729041Comment
I am debating between the SMA and the SolarEdge too. Seem SMA has advantage of the Secure Power Outlet and long term track record. SolarEdge has advantage of individual panel monitoring vs whole system monitoring, and may be a bit more efficient (but more chances of failure with the optimizers?). Do I miss anything more convincing?Comment
If the SMA inverter is mounted more than ten feet from the edge of the array you will need to factor in the significant cost of a DC combiner panel that includes Rapid Shutdown technology. Such as the Midnite Solar Birdhouse at over $500.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
The most convincing argument applies only to people in areas that have already adopted the 2014 NEC and so have to satisfy the Rapid Shutdown requirement on the DC side.
If the SMA inverter is mounted more than ten feet from the edge of the array you will need to factor in the significant cost of a DC combiner panel that includes Rapid Shutdown technology. Such as the Midnite Solar Birdhouse at over $500.Comment
I have not heard from anyone who has actually been in a situation to use it, but it seems well engineered for its purpose.
You do have to figure in the cost of the additional wiring to install the receptacle and switch and cords to get power from there to wherever you need it.
I would not try connecting it to my regular house wiring with a transfer switch since it just does not have the load capacity to be particularly useful that way.Last edited by inetdog; 04-10-2015, 07:14 PM.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
it does have a certain attraction to it.
I would not try connecting it to my regular house wiring with a transfer switch since it just does not have the load capacity to be particular useful that way.. One more question for the contractors. Thanks!
Hi All,
I for one would be going with 2 x SB5000 you get two power outlets in the event of a black out, and I believe SMA lengthy business history is precisely why they should be considered. Solar Edge might be ok but no one can tell you of an example of one that has been working for 15 + years, I can with SMA.
If you have no shading issues Id go sunnyboy but it looks like you might have a more complex system with some shade issues.
I know I do. Currently I'm stuck in between these 2 currently myself. If solar edge would come out with emergency power on their inverter I'd be sold right now. Do you care about the offline power of the sunnyboy?
If not then solar edge seems killer tech. Solar edge has power opt modules available in euorope that can be applied to a sunnyboy SMA system but we can't get them here.Comment
24xLG300N+SE7600 [url]http://tiny.cc/n7ucvx[/url]Comment
Does solaredge provide a worthwhile difference with partial shading over using a SMA inverter? I'm between two companies right now and one uses solaredge and the other will not due to solaredge not being in the business as long as SMA. Pricing is similar.Comment
