6kW system in Agoura Hills
Now considering ground mount, started a new thread: http://www.solarpaneltalk.com/showth...unt-vs-rooftopComment
Well, the panels were installed today. Final inspection and PTO pending. Ended up going with 9kW total at $3.17/watt. LG300s with a SE 10k inverter, P400 optimizers. It took 1 day for 7 people. I'm not a big fan of 1 day projects like this but I think it went reasonably well, but only time will tell of course.
Who did you use for the install?
And have you gotten the variable pool pump yet? A variable makes a world of difference ($50-60 less/month) - I am running mine for 8 hours a day: 4 hours at 280 watts and then another 4 hours at 380 watts = 2640 watts per day giving me a 1.2 Turn over rate... I might crank it up a bit more when we hit 90+ temps. And yes, they are VERY quiet!Comment
I used a local solar company, they are not big but are in this business for 3+ years, very responsive, I signed the contract a week ago and the panels are done today. I can PM you more details if you're interested. Negative on the variable speed pool pump, based on my estimates 9kW should be barely enough to 0-out my current bill on TOU/net-metering, the old pump is staying for now as a ballast that I can through out should my production drop over time or usage increase. Yes, I know this is not the smartest approach, but it works for me.Who did you use for the install?
EDIT: PM sentComment
it makes perfect sense, especially after shelling out for solar. If your system produces enough maybe you won't need to upgrade your pump
Well, the pump upgrade up front would probably have saved me $1.5k upfront overall as I could get a smaller array, but since the savings from the pump were unknown I decided to err on the safe side and just pay for extra solar. Plus replacing a pump could chain react into additional costs potentially, like broken fragile 20 year old PVC pipes, new electrical runs, etc.Comment
Gvl, could you share your installer's information? Thanks!I used a local solar company, they are not big but are in this business for 3+ years, very responsive, I signed the contract a week ago and the panels are done today. I can PM you more details if you're interested. Negative on the variable speed pool pump, based on my estimates 9kW should be barely enough to 0-out my current bill on TOU/net-metering, the old pump is staying for now as a ballast that I can through out should my production drop over time or usage increase. Yes, I know this is not the smartest approach, but it works for me.
That's a fairing large system, Congrat!Well, the panels were installed today. Final inspection and PTO pending. Ended up going with 9kW total at $3.17/watt. LG300s with a SE 10k inverter, P400 optimizers. It took 1 day for 7 people. I'm not a big fan of 1 day projects like this but I think it went reasonably well, but only time will tell of course.
Wow, great price and nice looking system. Does your installer come down to Orange County as well?Comment
Congrats gvl!
Do you have any close up pics of how they attached the panels to your roof?
Could you PM me your installer's info?Comment
I didn't take the pictures, but they used Quick Mount PV Classic Composition mounts, I don't know if all the screws hit rafters but the way flashing were installed looked legit.Comment
