Based on other discussions I have going in 2 other threads I'd like to explore a ground install option and keep this thread focused on it.
The main problems that surfaced so far:
1. SE roof orientation that is less than ideal by itself plus it doesn't play well with the current 2pm-8pm on-peak SoCal Edison window.
2. 15 y/o roof which is in okay shape but concerns have been raised I should replace it before installing the panels (I tend to agree).
I can kill these 2 birds with one stone - a ground mount install on a SW facing slope in my backyard. Or can I? Is this likely going to be more expensive than fixing the roof and adding more panels to match my usage? One obvious concern I have is what code says about the wires between the array and the panel, do they have to be under ground all the way? There is concrete on the side that is closest to the electrical panel. I have a cinder-block wall adjacent to the slope, will it be possible to just trench to it and then run EMT on it and then go under concrete only when there is 5 feet to the panel? Any other considerations?
