Most Popular Topics
I just had a 8KW system installed by an installer. Now I don't trust them...
What if the owner is also the DIY installer?
The owner has no right to manage and monitor their own system?
I don't think any installer would monitor any of the system they installed unless the owner call them for problem.8.2KW 32x(PVmodule+inverter)+online monitoringComment
FWIW, you can log into the Envoy directly using its IP address. I did that a couple of times when I first installed my system, I don't recall if it needed a password but if so it was something like "admin". There was a lot of interesting data, but I didn't spend a lot of time with it. I only mention it because it's not something most people would think of trying.Comment
If that's the case, when the owner sets up his account with Enphase, he lists himself as the installer by checking a box labeled something like "owner is also the installer". That makes the owner the manager of the system, and he gets the access to Enlighten Manager, which is what I have and sounds like what you want.Comment
I have it.If that's the case, when the owner sets up his account with Enphase, he lists himself as the installer by checking a box labeled something like "owner is also the installer". That makes the owner the manager of the system, and he gets the access to Enlighten Manager, which is what I have and sounds like what you want.
I turned on the system myself and installed the Envoy myself.
I called Enphase for help to set up the Wifi connection and activate the account before my installer got the chance to do it.
I am the OP.
I called Enphase and told them I am in a legal battle with my installer. They showed me how to remove their access on enlighten and then they changed my right from owner to Self-Installer. Now I have full access and the installer cannot alter anything and all micro-inverter serial numbers are preserved.
Now I need to see what the status is for the PG&E interconnection process. There seems to be some hold up by them.Comment
