Most Popular Topics
6Kw going in soon in Aliso Viejo
Hi Bob, could please PM me your contact as well? I've been lurking for a while and am ready to take the plunge.
Thanks!Comment
Ok... my first day of TOU DT action. Take these numbers at your own risk.... ALL ARE APPROXIMATED!!
From Midnight until 7am, I bought 6 KWH's of power off peak @ $ 0.13 a KWH for a total of $3.12
From 8 am until 11am I generated 10 KWH's of off peak power @ $0.13.. with a value of $1.30
From Noon until 5pm I generated 20 KWH's of peak power @ $0.22.. with a value of $4.40
From 6pm until Midnight, I bought 18 KWH's of off peak power @ $0.13 KWH for $2.34
Total Generated: $5.70
Total Purchased: $3.12
Net Gain : $2.58
Running these same numbers at a standard flat Tier 1 rate of $0.15 a KWH generates these numbers
Total Generated : $4.50
Total Purchased : $3.60
Net Gain : $0.90
I'm sure these numbers are wrong, dont hold me to the nearest penny ( or dime..or quarter!!) but it gives you ( and me) at least an idea of the differences between a standard " Domestic" account, and the "TOU-DT" account...
Time will tell at the end of the month...Comment
Your calculation are correct. That's the usual usage you see for Spring. Starting from July when Summer heat arrives, depends on AC usage, that is the key point. For me, most of the usage is at night time +EV charing, so I am leaning toward TOU-D-A which make more sense to me. Both my Summer (1800kWh/month) and Winter(1400kWh/month) usage are high, and I'm using Spring credit to cover the extra usage. Base on Spring TOU-D-T plan, the peak only pays $0.22 for the first 130% baseline which is about 390kWh). Unlikely you will get pay on over 390kWh@ $0.35 per kWh per month..... but your off peak for Summer/Winter are $0.26 and $0.25(tier 2), both are higher than your Winter credit @0.22. There's possibilty you might run into tier 2 rates @ 0.47 Summer and $0.35 Winter. I know SCE says TOU-D-T is good for solar owners, but I would question about that![ATTACH=CONFIG]6034[/ATTACH]
Ok... my first day of TOU DT action. Take these numbers at your our risk.... ALL ARE APPROXIMATED!!
Net Gain : $2.58
Net Gain : $0.90
Everone is different, but it wont hurt if you do some comparison. Here is my usage and pricing planComment
Yeah, based on InsaneOctane's work linked a couple pages ago, and comments in many other forums, it seems the TOU-D-A comes out ahead of TOU-D-T more often for solar owners, despite the less favorable peak hours.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
I see your installer used 10 gauge wire... my installer said they use 12 gauge but can use 10 gauge if I demand it. My question is there really going to be a difference in one versus the other?
I am using 36 of the enphase 215 micros (my panels are canadian solar 250w). He said the micro trunk cable is 12 gauge because they are 20 amp circuits with no more than 17 micros to a circuit.
Thiughts?Comment
If 12 AWG is large enough to meet code, the decision to go larger could be based on the additional cost of the heavier wire vs the value of the energy you keep because it has lower resistance. That decision will depend on how long the run of wire will be. For example 15 A going 20 ft (one way distance) in 12 AWG should drop 0.4%. In 10 AWG, the drop would be 0.25%. If the distance is longer, say 100 ft, it is 1.98% drop in 12 AWG, and 1.25% drop in 10 AWG. You can use a voltage drop calculator to compare your options.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
EDIT: as to not clog up his thread I posted the response on my ownIf 12 AWG is large enough to meet code, the decision to go larger could be based on the additional cost of the heavier wire vs the value of the energy you keep because it has lower resistance. That decision will depend on how long the run of wire will be. For example 15 A going 20 ft (one way distance) in 12 AWG should drop 0.4%. In 10 AWG, the drop would be 0.25%. If the distance is longer, say 100 ft, it is 1.98% drop in 12 AWG, and 1.25% drop in 10 AWG. You can use a voltage drop calculator to compare your options.
http://www.solarpaneltalk.com/showth...allation/page5Comment
I did 10ga to avoid the resistance of a long run between my S/W corner solar panels, on my N/E located electrical buss panel, for any future expansion onto my West facing side if a Tesla shows up someday, and for just good building practice.
"Code" usually mean the minimum acceptable amount.
I want to exceed code..Comment
i_love_solar_power_heart_custom_personalized_sticker-r00c3c178ad7344fca8015c4e64ef80fd_v9wth_8by.jpg
I currently have a -$48 dollar balance, growing towards summer.
Its all working out, per plan.Comment
