Looking good
Most Popular Topics
6Kw going in soon in Aliso Viejo
That is really nothing. I had even higher numbers. BUT....everything changes after EVs starting July 2014Attached FilesComment
Yup... I agree Bruce.
Here is something I just grabbed..
What is the equivalent wattage for led bulbs? What type of LED light is best? Read on for answers to these common questions. Cost ComparisonEquivalent Wattages and Light OutputComparing the FeaturesChoosing an LED Light Bulb LED light bulbs are quickly taking over as the bulb of choice, replacing incandescent bulbs atComment
From what the've told me.. big gains are available for pretty cheap.
My ducting is hung from the upper rafters... for starters, they cut it loose, lay in on the lower ones, and bury it in insulation.,
That alone is really supposed to help..Comment
If ducting runs through conditioned space, not insulating it is a waste of energy. Running through conditioned space or not, insulating ducting will change the temp. dist. in dwelling. Areas at the end of long runs will be a bit cooler in A/C mode. That may/may not be desirable, but easier to adjust/control via flow control than not being cool enough.Comment
First, get what you have checked out. Often, a tuneup helps. Then, insulate the duct work. I apologize if this does not apply, but there is always the unthinkable - turn the thermostat up.Comment
Bruce: I'm not sure a section is needed. The net, bookstores and popular literature abound with information about home energy conservation. There for the taking.Comment
