The electric bill came; here is the latest energy reserve buildup for winter. Despite even more clouds
than last year, I'm well above 2014. The heat pump gets most of the credit; usage here is quite small
(due to earlier conservation efforts) except when the heat goes on. Most of what the PV generates
is going to reserve, but that will change soon. If the winter is actually the predicted warmer, there
might be a big surplus. Bruce Roe
Sun hours
I am not sure if this was the one that I saw, but here is a 2012 article about the system. http://www.technologyreview.com/view...-solar-panels/
Unfortunately for them the idea did not catch on and the company stopped operations just this month.
This I've got to see. I have bolts to move & tighten on my 2013 version. The activators might beA good number of industrial applications use multipanel long row horizontal axis tracking.
Particularly good performance close to the equator.
I saw a clip last year about a system where a robotic actuator worked its way down the row tilting panels
and leaving them fixed in place as it went. Next scheduled axis change it worked its way back up the row.
One actuator for many panels.
here Friday, seem quite heavy. The robot moving them will be human. Don't know if I have a power
supply big enough for a pair of 24VDC motors, or will need to make something. Bruce RoeLeave a comment:
I saw a clip last year about a system where a robotic actuator worked its way down the row tilting panels and leaving them fixed in place as it went.
It looks like a single axis movement. What impressed me was they were using a Parker cylinder hydraulic system which are pretty well designed to last.Leave a comment:
It looks like an industrial design, made in this area. Doesn't appear to do 2 axis. I hope they find
some customers; trackers are less valuable with clouds and cheap panels. Maybe its for industrial
applications, are some of those single tilt axis? Bruce RoeLeave a comment:
I just saw a flyer yesterday about a new type of panel tracker made by HAS. I don't know the cost but it looked pretty impressive.Its getting late, but I may yet manage to get my south facing panels vertical for this snow season. The
24 braces to hold them are done; the issue is how to raise & lower each platform having two braces.
I ordered a couple linear actuators with a 52 inch stroke (about enough) and a 5000 lb capacity (overkill).
They run on 24 VDC, should be able to fine control them with adjustable voltage.
But they haven't arrived yet, so the mechanical design is still in doubt. Worst case the whole thing will
fall on me. IREA tour this Sat. Bruce Roe
Solar Panel Tracker_HAS-Flyer_091115.pdfLeave a comment:
Winter inclination
fall on me. IREA tour this Sat. Bruce RoeLeave a comment:
Why don't u try type the longitude and latitude on NASA website, u can see the data for past years.I was just thinking about the definition of SUN HOURS. Like, with my sun rise to sunset being
10:50 hours now, the total energy hitting a given panel might be equivalent to 5 hours of perfect
sun noon. So then its 5 SUN HOURS that day, location, and alignment.
Working this backwards, harvesting 110 KWH divided by 15 KW inverter maximum (clipping)
level, gives 7.33 equivalent SUN HOURS. The idea of course is to stretch the sun day by adding
panels directly facing the rising & setting sun. Comparing this to the basic sun hours could be
a multiplying factor for the panel arrangement. Probably the factor doesn't have a name? I'm
still looking for a tool to use, to predict this factor. Bruce RoeLeave a comment:
Probably my problem isn't your problem. I looked at the display cable on my 7.5, but nothing was looseWell I looked very closely at the connection on the display. The insulation on the cable where the connection is made to the display is dis colored which makes me believe it is a loose connection. Heat or arcing maybe going on. I have reconnected and reseated the connection but still have the same problem.
My diagnosis is that the connectors do not make a proper connection do to a manufacturing defect. I am going to replace door, display, connector and plug in panel.....all under warranty.
I do not believe your jumper wire will fix the problem I see. Inspect your connection very closely and see if there is indications of heat.
or burned. But wires should not be discolored from heat. Lets see what develops with your repair.
Well I looked very closely at the connection on the display. The insulation on the cable where the connection is made to the display is dis colored which makes me believe it is a loose connection. Heat or arcing maybe going on. I have reconnected and reseated the connection but still have the same problem.Do put those holes close to the hinge so the jumper is short. And make sure nothing inside
is at risk. Some risk of voiding the warrantee I suppose, don't worry about such things here.
I tapped for 6-32 so it could be serviced from the outside, but nuts & bolts work with some
of those star contacts to help cut through, and clean the spots on the aluminum.
If I am right, replacing parts is only a temporary fix. Someone else suggested it could be
a loose door cable, but I didn't touch that and its cured. Let us know. Bruce Roe
I do not believe your jumper wire will fix the problem I see. Inspect your connection very closely and see if there is indications of heat.Leave a comment:
Do put those holes close to the hinge so the jumper is short. And make sure nothing insideBruce, I have the exact same issue with the older of my two Fronius inverters. The older model has the hinged door but the newer model is bolted closed and they moved the DC cutoff switch is mounted on the bottom externally, thus no need to oped up the swinging door.
Well I called Fronius and they will, under warranty of course, replace the door and include
a plug in module. Maybe I'll try your fix first.
a loose door cable, but I didn't touch that and its cured. Let us know. Bruce RoeLeave a comment:
Bruce, I have the exact same issue with the older of my two Fronius inverters. The older model has the hinged door but the newer model is bolted closed and they moved the DC cutoff switch is mounted on the bottom externally, thus no need to oped up the swinging door.New operational issue. The Fronius inverters have performed well for a couple years, running at
clipping level much of every sunny day. The lower doors have a manually operated readout, and
access a DC cutoff switch and some other stuff while running.
The other day I opened a door, and the inverter went into reset and power up cycle. It
happened again, I don't need this. Lets see, the case is made of extruded aluminum, and
the door is the same. A clever mechanical design allows the 2 to slide together without a
separate hinge assembly. Well that is fine, except that aluminum likes to form a non
conducting oxide coating. I theorize the door and case are no longer electrically connected,
and static charge/discharge between them is disturbing the electronic controls.
Cure, I drilled & tapped some holes. Short wire jumpers were added at the top and bottom
of the door hinge area, to keep the door securely connected to the case. Problem cured. I
hope this doesn't mean radiation of radio interference will also be on the increase; it was in
good shape initially. Otherwise, I will be adding more jumpers. Bruce Roe
Well I called Fronius and they will, under warranty of course, replace the door and include a plug in module. Maybe I'll try your fix first.Leave a comment:
Yes I know that those really wild area deer do such numbers. But experimentation here with
these zoned AG deer indicates they generally will not attempt a 7', let alone an 8' fence. And
the doe isn't going to go where the fawns can't follow. I'm thinking the first electric will be just
barely above the 6' mesh, so anything trying to crawl over won't get under it. 3 more runs
extending up to 8'. Not sure it really matter if the top are electric since the deer would be off
the ground anyway. Not so a climber though.
I'm not so concerned if the deer see the wire or not. If they end up breaking it, I'll probably
try barbed wire instead.
There are 10' T posts sticking up 8'. If those aren't enough, I have been known to clamp on a
piece of rebar to add a couple more feet. BruceLeave a comment:
Deer will not even notice a 6' fence. Week old fawns can make a standing hop over a 3' fence, an adult at trot can easily clear 8'....... a new fence is going up. Small
mesh 6' high and electric fence up to 8' ought to keep out dogs, deer, and anything trying to climb
over it. When all this is in order, relocation of existing panels can be accurate, shade free, and
perhaps much easier to tilt for snow season. Won't be done this year. Bruce Roe
We use 6' fencing, with 2 tension wires above it at 7' & 8' with flags on both wires so the deer can see the wires.Leave a comment:
