I know some charge controllers have built in support for what I want; but mine doesn't. I like to be able to monitor the battery bank charge from anywhere; if possible using my cell phone. Something that can allow me to set alerts, for example, if battery is at 60% send alert to my cell phone. Any suggestions?
Over the Internet battery bank monitoring
1) Upgrade your charge controller, either Midnight Classic (via Remote App and ethernet), Morningstar MPPT 60 via ethernet
2) Mooshimeter bluetooth meter & app, and let the app go over the internet. (may have to ask for a new sw feature)
https://moosh.im/wiki/index.php/Using_the_Apps https://moosh.im/mooshimeter/Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Well i have a midnite classic SL 150 but it doesn't comes with an ethernet port for Internet connection. So I guess option 2 is what I'm going to do.
thank you Mike!Comment
I take that back, option 2 is not doable. It requires AA batteries which means it cannot remain functioning permanently.Comment
What about an internet wifi web cam pointed at a computer or the LED screen on the Charge Controller ... LoL ... I am doing that because I do not want to open up a port and a static IP address.285Wx9 / MNClassic 150 / CSW4024 / TrojanL16H-ACx4Comment
I am following this closely, I would expect that there is some sort of 3rd party option with shunt/volt meter that can sit on the network out there somewhere that isn't homebrew.Comment
Also interested in configuring a solution to this that might work with the Schneider gear which I believe can do this if you have an internet connection (i.e., a conext combox connected via router and internet). Don't know about cellular, but we can use a higain antenna system on a public Wi-Fi type of system (ie no static IP address except via third party type solutions).
Lots of our neighbours have put high gain dishes in to connect to internet via a public Wi-Fi hot spot that's 3 nautical miles away over the salt chuck (water). Will be interesting to see how the Fresnel zones (variation of signal strength with elevation due to multipaths interfering constructively/destructively) affect optimum antenna height ....
Cheers - Solar IslandersComment
I believe for the Schneider gear you are going to have to have a static IP. At least that is what Schneider told me.Also interested in configuring a solution to this that might work with the Schneider gear which I believe can do this if you have an internet connection (i.e., a conext combox connected via router and internet). Don't know about cellular, but we can use a higain antenna system on a public Wi-Fi type of system (ie no static IP address except via third party type solutions).
Cheers - Solar Islanders285Wx9 / MNClassic 150 / CSW4024 / TrojanL16H-ACx4Comment
I wonder if anyone has had success with using the Schneider Combox for remote access without a static IP address using something like the free no-ip service or the $25/year DynDNS service which creates a static IP address via an associated domain name?
Surely Schneider could update firmware to get around the need for a static IP address as this is very limiting to the functionality and market for the Combox (which seems expensive for what it does .... :')
PS: Regarding providing non-AA battery power for Mike9025's "Option 2 Mooshimeter Bluetooth Battery Monitor": How about: a pair of dummy AA battery shells (i.e. wooden dowels with brass washers on each end) put inside the meter that are wired to an external ni-cad or other rechargeable battery, with a 3.2 Volt voltage regulator supplied by a small solar panel?
Using an independently grounded supply like this would get around potential ground reference issues that could arise from running the meter off the main bank with a voltage regulator driven off of the main bank . I guess that the meter's Bluetooth data would get relayed to the internet (somehow) by an old cell phone permanently dedicated to this task?
SolarIslander I'll install a Schneider Combox next week. I have a satellite connection and my WiFi router is flashed with dd-wrt. I'll use a dynamic DNS service together with port forwarding.Comment
The Schneider Combox does exactly what I want. But it seems that is compatible only with Schneider gear. Correct me if I'm wrong.SolarIslander I'll install a Schneider Combox next week. I have a satellite connection and my WiFi router is flashed with dd-wrt. I'll use a dynamic DNS service together with port forwarding.Comment
