How much did I save? How many kWh did we use last month?
There are point of use heaters that mount right under the sink or the floor in the bathrooms that kick on as soon as there is flow in the hot water pipe. Alternatively there are pumps with temperature sensor that bypass the flow out of the hot water pipe to the cold water pipe until the temperature in the hot water side hits a preset temp .There is lag in hot water but at least its going back into the water system instead of into the sewer.Comment
Yes but kind of violates the KISS idea, when you have several baths plus kitchen, laundry.There are point of use heaters that mount right under the sink or the floor in the bathrooms that kick on as soon as there is flow in the hot water pipe. Alternatively there are pumps with temperature sensor that bypass the flow out of the hot water pipe to the cold water pipe until the temperature in the hot water side hits a preset temp . There is lag in hot water but at least its going back into the water system instead of into the sewer.
Bruce Roe
Absolutely. We could take cold showers, or cold-for-60-seconds showers. We could skip showers or take baths. But this worked for us, cost us very little, and saves about 600 gallons of water a year. ($4 a year, in other words, and the pump cost me $40, control stuff cost me $15.)
