Stacking non-identical trace/xantrex sw/swplus 5548 inverters ??
SWI Cable drawing
I have looked for this Dwg for a long time. I have 2 SW 4048's and have just run one then the other. One on one side of the 220 line and one on the other but not able to run both at the same time. ThanksI have two SW+5548's and two SW4048's both stacked.
I can tell you the stacking cable in the same for both. (attached schematic)
The SW+ and SW may have different lock times depending on SW rev of non-plus unit. My two 4048's that are stacked have different SW rev's and the newer unit takes about a minute longer to re-engage when grid returns. Other then that quirk there is no problem. I have never tried connecting the plus to non-plus units. I can tell you the plus units hang on a bit longer for a startup surge current so they are good when you have a tough motor to start.
My guess is the stacking will probably work. Other then controlling simultaneous shutdown/activation and off grid phase sync, stacked units operate pretty much independently.Comment
If anyone has a schematic diagram for the SWI (series stacking cable interface), I sure could use it. Looks like the link in the previous post is broken. Thanks!Comment
Here you go!
Used this cable to stack a 5548 and a 4048.Attached FilesComment
On the stacking cable schematic, which end goes to which inverter ?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
