Stacking non-identical trace/xantrex sw/swplus 5548 inverters ??
  • Briank
    • Dec 2011
    I just found an awesone deal on a trace sw5548 and a xantrex swplus5548
    I want to stack these units for 240volt opereation.
    Instructions on stacking specifies identical units.
    Does anyone have info on stacking non- identical sw5548's?
    Should it still work fine or is the stacking interface on these two units not going to sync?
    Thanks for any info.
    Brian
  • RCinFLA
    • Aug 2011
    • 41
    I have two SW+5548's and two SW4048's both stacked.
    I can tell you the stacking cable in the same for both. (attached schematic)
    The SW+ and SW may have different lock times depending on SW rev of non-plus unit. My two 4048's that are stacked have different SW rev's and the newer unit takes about a minute longer to re-engage when grid returns. Other then that quirk there is no problem. I have never tried connecting the plus to non-plus units. I can tell you the plus units hang on a bit longer for a startup surge current so they are good when you have a tough motor to start.
    My guess is the stacking will probably work. Other then controlling simultaneous shutdown/activation and off grid phase sync, stacked units operate pretty much independently.
    • wasif
      • Feb 2014
      Thank you for your helpful response, I am doing the same thing with two SW4024, need a stacking cable or diagram, so far your response was the best.
      Wasif
      • RCinFLA
        • Aug 2011
        • 41
        Wasif
        All SW's and SW+'s use the same series stacking cable, as shown in schematic. You can make up simply with DB25 ribbon version and ribbon cable. This is what they sell you if you buy one. I did not like the ribbon cable and made mine from multi-wire circular cable, soldering all the connections on DB25 connectors. Looks much better and no exposed ribbon cable.
          Although it may not matter for this application, the circular cable is less susceptible to interference from electronic noise. Especially if it is shielded. (But only connect the shield on one end.)
          • Firstlight
            • Mar 2014
            Firstlight
            Thank you for posting the schematic. I have been trying to buy a stacking cable without success. This will help me build one.
            • nomatter
              thankyou
              Great
              • CodeGenius
                • Oct 2014
                Thanks for the schematic
                This is just what I need.....
                • jbinverters
                  • Feb 2015
                  Thanks for the post I have a lot of customers asking for these cables
                  • xtian777
                    • Feb 2015
                    Thank you !
                    Thank you ! This is what I needed for a long time !
                    • mtndriver
                      • 3
                      Thanks for the info. We are trying to replace the dumb transformer we currently use with another 5548, but are also faced with adding a 5548+ to a non-plus 5548. We will see how this works...
                      • Oscar Chacon
                        • Jul 2015
                        Stacking cable
                        Thank you, you help my problem
                        Oscarhttp://www.solarpaneltalk.com/images/smilies/icon_e_smile.gif
                        • Oscar Chacon
                          • Jul 2015
                          Stacking cable
                          Wow this is what i was looking for
                          thank you!!
                          • prc
                            • Sep 2015
                            Big help
                            This thread was really handy!
                            Thanks all!
                            • cbgatlin
                              • Sep 2015
                              stacking trace sw4024
                              I need to find a pin out schematic or cable for serial stacking of 2 trace sw 4024.
