I don't have SPS on any of my systems. I haven't had a chance to install a new -41 yet and none of my customers were that interested since our grid rarely goes out here. The system I have with TIGO is a -40 and would not work with SPS without a workaround to supply power to the TIGO module.
micro-inverters or optimizers when shading is major issue ?
I don't have SPS on any of my systems. I haven't had a chance to install a new -41 yet and none of my customers were that interested since our grid rarely goes out here. The system I have with TIGO is a -40 and would not work with SPS without a workaround to supply power to the TIGO module.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Another thought: the following trick would work with micro-inverters or optimizers (or other TS4-X devices), but not with just a simple string. You could put all optimizers/TS4-X's along the top edge of a ground-mounted array, with pairs of wires going from the panels up to the top. So no dangerous voltage anywhere near the ground even if the lower edge of even a fairly small array (3x5) is near grade. Higher cost for cabling, but no fence costs; main motivation for me would be aesthetics of no fence. (See thread: https://www.solarpaneltalk.com/forum...string-systems)Comment
Its about time we had a good old debate about this topic ,as equipment, models/brands come and go its good to keep up, I like this guys stuff, https://mcelectrical.com.au/inverter...rs-optimisers/ as it pains me to give any other Aussie Solar Co seo help but this guy does actual testing, **** he flew to Israel to talk about inverters, worth having a read though, cheersComment
Well, this article is pretty on-point about all we've been discussing here. I'm guessing a certain one of us will take issue with its conclusions: https://mcelectrical.com.au/blog/tig...el-optimisers/
Glad you think this is a good review, it is the one I brought up at post #60
Good to know you judge the info sound
Hello All,
Not true if each string is independent which is far more common than not these days. I don't think there's a string inverter on the market anymore with only 1 MPPT channel.Comment
"it can" does not mean "It will"
It also says "Half of the panel", may be as you said because most Inverter have two MPPTComment
REASON 1 – OPTIMISING PREVENTS SHADED SOLAR PANELS FROM DRAGGING THE ENTIRE STRING DOWN.
REASON 2: OPTIMISERS ALLOWS PARTIAL PRODUCTION ON SHADED SOLAR PANELS
REASON 3 – SOLAR PANEL DIODES ARE NOT OPTIMISERSOutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
This is what happens if 2 panels are shaded and each string is independent. The unshaded panels are unaffected. Because this shade is only over 2 cell groups the result would be ~identical with optimization.
screen-shot-2018-07-12-at-11-47-44-am-png.316409.png[/QUOTE]Last edited by nwdiver; 10-21-2019, 02:51 PM.Comment
If you shade a panel, the bypass diodes will engage and the unshaded panels continue producing at full power. The only exception is parallel strings. If you have parallel strings of 12 and 1 panel is shaded you now effectively have a string of 12 and a string of ~11. If 1 panel is shaded on a 4kW string of 12 panels you don't lose 50% or 40% or 30% or 10%. You lose at most ~8%. ~3% if only 1 cell group is shaded.
In this test, the left three panels were significantly shaded. To prevent the inverter from turning off from under-voltage, the inverter reduced the current, so the bypass diodes did not engage. This meant each panel still produced 30 volts, but only 0.5 amps.
With the same amount of shade on the optimised panels, the shaded solar panels performed poorly. But the unshaded solar panels were able to run at a higher current, (so higher power).OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
That is NOT the only exception. The even give an example in the article. If you block enough to start effecting the voltage such that the string voltage is outside the string inverters MPPT range then it will shift them all until it gets back into range.
Parallel strings are more common in larger systems.
There's no reason to ever have parallel strings on a residential system with current inverter options. I don't think anyone makes an inverter with 1 MPPT channel anymore. All the new inverters I've seen have 2-4 channels. The last string system I installed was 22.77kW using (2) 7.7kW SMA inverters. 6 strings each with its own MPPT channel. Cost <$3k for the inverters. With optimization it would have cost ~$4k more. Instead of spending ~$4k on optimizers I spent $4k on ~2kW of solar. Pretty sure my annual yields will be higher with 22.77kW of unoptimized vs 20.77kW of optimized...Last edited by nwdiver; 10-21-2019, 03:03 PM.Comment
There's no reason to ever have parallel strings on a residential system with current inverter options. I don't think anyone makes an inverter with 1 MPPT channel anymore. All the new inverters I've seen have 2-4 channels. The last string system I installed was 22.77kW using (2) 7.7kW SMA inverters. 6 strings each with its own MPPT channel. Cost <$3k for the inverters. With optimization it would have cost ~$4k more. Instead of spending ~$4k on optimizers I spent $4k on ~2kW of solar. Pretty sure my annual yields will be higher with 22.77kW of unoptimized vs 20.77kW of optimized...OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
