Yes, it should help but your structure doesn't use the supports of the array. That makes a difference already. The other picture has the vertical wall using the same supports as the array. That does direct the forces more sideways versus up in the air but I am not sure how much difference it would make.
mount panels on top of a 40 ft container
I figure, if the panels fail before the support, you are done. Many use those silly clamps
that can slip out of place if things move a bit. Others use 4 bolts to the flimsy panel frame,
but I suppose one could use 12 evenly spaced bolts to raise the stakes.
My Reason to Ground Mount #17 is you can be less concerned about a possible failure.
Bruce RoeLast edited by bcroe; 06-27-2019, 09:47 AM.Comment
If it ever fails I will let all here know. I might add, last October, it survived a hurricane crossing over the peninsula and directly over the area. We had about 4 hours of pretty intense wind and rain. See the image of the track of Hurricane Rosa.
Last edited by littleharbor; 06-27-2019, 10:07 AM.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
