I purchased a used SE7600H-US inverter. I plan to use it with a new solar array (>11 kw) and do EV charging. My all electric home (under construction) will be > 3300 sq ft with AC in a very sunny but warm location (with very expensive electricity rates), with heated swimming pool (10x58') and 2 EVs with > 50 kwh batteries. I am not sure what my usage will be, so I will start with an oversized array and the SE7600H and add more panels if needed
I have a few questions:
1. I read that I can also connect a EV charger kit to the SE3800H-US inverter. With 2 EV cars, would it be better to install both a SE7600H and SE3800H than one SE11400H, so that I can charge 2 EVs at once with solar boost? (The EVs that I am looking at can charge at 40 amps).
2. Do I need to buy the SE EV charger kits, which are rather expensive, or can I connect a cable with appropriate size wire and connector such as:
https://www.ebay.com/itm/J-Plug-J177....c100011.m1850
3. What is the SE part number for the EV charger and does anyone have an installation manual for the EV charger kit?
4. How much power, greater than load demand, do I need to generate from my arrays to enable the solar boost mode in these inverters?
5. If I go to a 2 inverter system, how are the house loads connected to them? I presume in series (one main panel) rather than parallel (2 separate panels).
