Kevin will you put on here photo copies of the relevant electrical approvals done here in Australia. for your brand of micro. inverters?
Micro-inverters in Australia?
Hi John, thank you for your reply. you can find APS micro-inverter information with the links below:
The Clean Energy Council is the peak body for the renewable energy industry in Australia. We help residents & industry transform energy systems for a smarter, cleaner future.
Anything else I can help, pls let me know.
KevinComment
The link you gave was to the Clean Energy Council..
The Clean Energy Council does not approve inverters - it is the electricity utility which is responsible for approving inverters used in its jurisdiction. Approved inverters should have a Certificate of Suitability number and a date of testing. The testing date should be less than 5 years old.
EXAMPLE I live in Queensland do you have approval certificate from either or both ENERGEX or ERGON ENERGY ??Comment
Hello John,The link you gave was to the Clean Energy Council..
APS Micro Inverter has passed all the necessary performance test and safty test, got approved by SAA and were listed in CEC. It is accredited in Australia and also
is qualified to sell the 1st one here.
We could continue our discussion and exchange information about the certificate through below my contact info. if you like.
Thanks John.
KevinComment
Links can be posted in your profile, not on the forum pages.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Yes the APS microinverters are fully approved in Australia.Comment
Hi...did you have a look at Enphase microinverters? they have address in New Zealand so maybe they also supply to Australia? I am speaking to them later so i can also ask...
Also you could check out one of the pv monitoring sites like pv-log, which is another solar community site for pv, if you register yourself on there then you can then browse installations using different inverter types, make solar friends or ask people directly (it has a solar friends feature)
good luck...Comment
I made a quick phone call to Energex the major power supplier in south east Qld and they said they have NO microinverter on their approved list of compliant inverters.
The only complience that is shown on the website is a certificate showing its approved by some organization in China.
Ithink Iwould be asking them to show the electrical authority approval for their city before buying them.
Also its not legal to install any inverter to the grid supply except by a licensed electrician.Comment
