Btw, forgot to upload a closeup pict of above cheap chinese powerbank
question about discharge while charging
Cat Fully Charged PurdyC.jpgMy charger has an indicator light to show when the cat is fully chargedPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You are not understanding basic physics. It is no more complicated than a bank account.
If you open an account and deposit $10 initially, spend $5 per day and only deposit $3 per day you are bankrupt. and broke in a week. That is what your battery will be, exhausted and broke. The difference in physics, there is no one to give you money or extend credit. Out of power and your toast. No one can change that.
In electric energy money is Watt Hours, You have to generate more than you use. Use more than you generate and you are done. You cannot run an engine with no gas no matter what you think or do.Last edited by Sunking; 09-08-2016, 08:41 PM.MSEE, PEComment
Extending that analogy for a moment:
Suppose you start with $10 in the account.
Each day you visit the bank, go up to the teller and say: Here is $5 to put into my account and I would like $4 back please.
Are you depositing and then withdrawing? Are you withdrawing and then depositing?
Are you depositing only $1 and not withdrawing anything?
Are you depositing and withdrawing at the same time?
The answer is that it does not matter. You have the same money in hand and the same amount in the account either way.
Now if you deposit $4 and withdraw $5, you are definitely, as in Sunking's example, withdrawing from your account and it will end up at zero.
The electrons do not really care how you describe what is happening. What counts is the results.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Its really charging WHILE i lightup the bulb. This means, more amps coming in than the lamp uses... Or not?? When the sun goes down it still lightup. Like someone said above my powerbank(circuit) seems to work like a chargecontroller
... For me this is then a effective cheap solution. Such a powerbank is about the same price as a chargecontroller but then incl one or more li-ion batteries
Question:
I found this circuit somewhere on internet. If Im able to make this and the bulb continuously burning, will it work like above powerbank??
Why making myself? I want to decide myself what kind of li-ion or another type I want to use
Attached FilesLast edited by fivewin; 09-09-2016, 01:58 AM.Comment
The problem might be that a solar panel may not work with that device as a solar charge controller will with a battery. Again you can try it but the results may not be to your satisfaction.Comment
Sunking, has anyone spoken to you about charging for your classes ? Such a deal for free !!
Kind of. I have done a few classes for Mike Holt, tons of classes during my years in Generation and Communication for Employees and Contractors. Even taught two semesters at a junior college when I got laid off in 2003 before I went into biz for myself. Hated that job.
MSEE, PEComment
Yes to both. They would not let me beat on the knuckleheads to root them out and get rid of them. I am serious, I could not fail a student unless he/she missed 12 days or more . That is 2.5 weeks of a 9-week semester. As long as they showed up, they got a 1.0 or D minimum. School did not want to hurt their poor dear little feelings. Kind of scary when you think about it.MSEE, PEComment
Absolutely has something to do with it. That is exactly why private schools and universities usually provide a better education as they take no Federal Funds and the Strings attached to Fed dollars. In private schools slackers are sent back home.MSEE, PEComment
