10.4 KWh DIY Ground Mount Finally Online
    • 14926
    Any chance for a pic or 2 of the backside showing racking/supports ?
    • JFinch57
      • Feb 2015
      • 159
      Can you post a picture of the back? My self installed 10.8KW Unirac system is set in almost 5 yards of concrete. The 2.6 yds sounds a bit light, but I'm sure that it meets spec.
      This gallery has 3 photos.
      Jeff, BSEE, 22.3KW, 45-240W w/M190, 46-260W w/M250
        • 15124
        Another nice installation.
        Did you do anything to reduce the amount of shade coming from those trees to the left of the array?
        • jorgey
          • 34
          Originally posted by dvseliteus
          Nice installation jorgey!
          Those look like pretty long spans for your vertical pipes.
          I think that the picture is a little deceiving, it is all within IronRidge's specs and the pipes are 3" galvanized steel.
          • jorgey
            • 34
            Here is a picture that I took 10 days ago of the backside. The picture is after a snow storm and I had just finished brushing off the panels. When I was done, I checked the SolarEdge app on my phone and was surprised that it was already generating over 3Kw with very little sun coming through. (You can see the sun just starting to peak through all of the clouds.)
            The structure itself is 3" galvanized steel with IronRidge diagonal bracing, mounting hardware and XR1000 rails.
            Although not needed and not called for in the plans, I installed a disconnect for each string at the array. If I have to do some maintenance, I can shut down only half of the array at a time and still keep generating.
            • jorgey
              • 34
              Very nice.
              It looks like you used 2" pipe, is that correct? If I would have used 2" that would have doubled the number of piers and I would have then used about 5 1/4 yards of concrete. (Similar to your setup.) When I decided to go with the 3" pipe I was only thinking about the strength and having to drill less holes and have less piers. I wish I would have thought about how heavy the pipe would be. It was a beast!
              • DaveDE2
                • Feb 2016
                • 185
                Looks like a bombproof professional installation. Nice job!
                Where are you located? Looks like Colorado front range.
                • jorgey
                  • 34
                  Thanks
                  You're close, I'm next door in Utah.
                  • JFinch57
                    • Feb 2015
                    • 159
                    Yes, trimmed back the Maple tree, but right now there are no leaves and the sun is low! There's an oak tree to the right that's coming down soon. Also, I'll be getting a large construction lift in the spring to paint my house. That will make the tree trimming a breeze!
                    • JFinch57
                      • Feb 2015
                      • 159
                      Originally posted by jorgey
                      Very nice.
                      Yes, the Unirac LA setup only uses 2" schedule 40 pipe. For the legs I drilled and tapped using a 7/16" X 3" galvanized bolt to anchor them.
                      • DanS26
                        • Dec 2011
                        • 972
                        Great job.
                        It appears that you created a ground ring around the array since you stated that you installed four ground rods. My only question is why you spiraled the GEC around the outside posts instead of a straight and short route to the rods?
                          • 5201
                          The problem with trimming, is in a couple years the tree is right back at the same height, if not as dense. The significant other says
                          I might as well just cut them down (which doesn't require hiring any equipment), so that is what I will do. Bruce Roe
                            • 14926
                            I love trees - to my south.
